Is there a way to get auto-completion for tags:: page|
in the way one gets completion for [[page|]]
Don’t thing so. You can alternatively use #
instead of [[]]
—might be quicker.
I am using tags::
at the beginning of a page to specify all the tags (or other pages) that are related.
Do I achieve the same with a list of #
or [[]]
(I switched from #
to tags::
a while ago)
Yes (though I suspect you might have misunderstood me). These are the same:
tags:: Tag1, Tag2, Tag2
tags:: #Tag1 #Tag2 #Tag3
tags:: [[Tag1]] [[Tag2]] [[Tag3]]
Only the latter two will get you autocompletion.
I’m not recommending not to use tags::
