Reported on Github: Blocks with the same property key (but different value) as their parent don't show up on queries (advanced and simple) that match all values (incl. empty) · Issue #3390 · logseq/logseq · GitHub
- Describe the bug
- Blocks with the same property key (but different value) as their parent don’t show up on queries (advanced and simple) that match all values (incl. empty)
- What steps did you take before seeing the bug? The more specific, the better.
- Created a block. Set property
typee:: book
- Created a child block. Set property
typee::article
- Created a two queries
- Just one match: the parent
- If I indent the second block underneath a new´one, so that it becomes a grandchild (or further indent it) of the first block, both queries work.
- Both queries also work if the blocks are not descendents.
- What did you expect to happen?
- Both queries would match 2 results
- What was the technical context (i.e. what version of software, browser, operating system, etc.)
- On Widnws 10, using the desktop ap, v. 0.51
- Please attach any images or files that can help us reproduce (screenshots, screenshares, etc.)
