I used to have some Useful Links in the Contents Card but I want to keep that very compact, with only the Quick Capture and one or two other items that i often use and want to quickly access with the “Toggle Contents in sidebar” shortcut (Default Alt+↑+C
). So I’d like to move these blocks from the Contents page to another easy to access place and the most obvious would be the “Help” tab, as they are also “helping” data.
Is there any way to add to the Help items?
PS: I know I can create a “Favorites” Page …
