Changing file hierarchy only available after re-index?
If I have a file named Tony. Then I rename it to be Cats/Tony. Then go to the Cats page I do not see Tony listed. The only way I have found to make this work is to re-index which then logseq picks up the hierarchy.
Is there a better way to move files into hierarchies?
I went ahead and created an issue for this. changing file hierarchy only available after re-index · Issue #4941 · logseq/logseq · GitHub
