try to reindex, then close the app and restart. it should say it detected a custom.js then ask for permission to run it => grant the permission.
I’m risking being pedantic and splitting hairs here, but I think there might be something useful to distinguish between here: I think namespaces serve best as contexts that are narrow enough to unambiguously resolve a name to a particular concept. That’s slightly different from a “type”. Sometimes the namespace will match the type, but sometimes it won’t. Here are two contrasting examples:
Namespace and type happen to line up:
Book/Matildacould be a name which refers to the book “Matilda”, whileMovie/Matildacould be a name which refers to the movie of the same name.- In the context of the concept
Book,Matildarefers to one thing, while in the context of the conceptMovie,Matildarefers to another. - As it happens,
Book/Matildais a book, whileMovie/Matildais a movie.
Namespace and type don’t line up, and that’s okay, too:
Acme/Org Structurecould be a name which refers to the organizational structure in the Acme Company, whileGlobex/Org Structurecould be a name which refers to the organizational structure in the Globex Corporation.- In the context of the concept
Acme,Org Structurerefers to one thing, while in the context of the conceptGlobex,Org Structurerefers to another. - But in both cases, the “type” of the entity the name refers to is an organizational structure.
Acme/Org Structureis not “anAcme”, andGlobex/Org Structureis not “aGlobex”.
All of which is to say: I think both namespaces and type::s are useful, for separate (if often overlapping) things. I haven’t seen much (or maybe anything?) use type:: yet, but a simple use might be a plugin which puts an icon in front of each link based on the link’s type. You’d expect to see something like:
[[Book/Matilda]]
[[Movie/Matilda]]
[[Acme/Org Structure]]
[[Globex/Org Structure]]
(And having written all of that out, I now really want to write that plugin.) ![]()
Following up: Awesome Links does this! It uses the property page-type:: by default, though I’ve changed that to type:: for myself because I like it a little better. Then links to those pages inherit the icon:: of those pages’ types.
Just discovered this from another thread, do we have a way to support relative url when creating namespaced page references? Is this possible with logseq plugin api?
Like when you type [[./Ideas]] from [[CoolProject]], it will automatically expand to [[Cool Project/Ideas]]?
I’ve found I often need to do this, as there are usually multiple projects that I have to create sub pages for.
