Favourites in the left hand area are sorted alphabetically. This is not always a useful ordering.
Is it possible to create a custom order ? If not, could this be made possible in future version ?
It is possible to reorder by dragging and dropping with your mouse.
Thanks. I was confused by the green + icon that appears if you drag an item. I expected it would nest the item under another item rather than change the order at the first level.
