(desktop, windows, v0.4.4)
If you use the right click on bullet point menu item “cut” and paste it somewhere else, all the sub blocks are lost.
example:
- this is the main block you want to cut
- this is sub-block number 1
- this is sub-block number 2
If you now cut the “main block” and paste it somewhere else, only the main block itself gets inserted. You lose sub-block 1 and 2.
so you only get:
