I installed the latest non-db-version of logseq on my linux and installed awesome ui afterwards. Unfortunately now logseq opens with an instant error-screen and i’m not able to enter the settings to deactivate any plugin.
I found various links with various information, but nothing i can apply to my situation it seems:
https://www.reddit.com/r/logseq/comments/1gdgry7/how_can_i_remove_the_long_form_plug_in_from_logseq/
How do I fully delete Logseq + all application metadata/app data?
So what i got is the path on linux should be:
$XDG_CONFIG_HOME/Logseq or $HOME/.logseq
But if that path is available i could not find anything about plugins or an awesome plugin. So, how am i able to disable the plugin?
Best regards
