Hey,
I’m using Logseq on the Mac. When I install a new theme from the Marketplace I’ve found that – regardless of the theme – the CSS describing the “+ Create” button in the bottom left is not updated. I’ve attached a screenshot below.
You can see that the default “green” theme is showing through the new theme I’ve added. Am I doing something wrong, or is this a bug?
I’ll also add: After I install the theme, toggling light and dark themes with t t
toggles me between the correct (newly installed) light theme and the default (green) dark theme (after a momentary transition to the newly installed dark theme).
Thanks
