The spacing between “Now”, “Overdue”, and “Scheduled and deadline” seems inconsistent. Any idea why this may be happening? Thanks!
The scheduled and deadline query is a build in query you can only turn on or off in the config file. The other two are custom queries that are specifically defined in the config file. This is apparently how Logseq renders these two things.
I don’t think there is much to be done about it manually. Unless someone knows more than I do. Then I’ll happily be corrected.
The only custom query I added is “overdue”. Both “now” and “scheduled and deadline” were there by default.
Oh I think I know: the gab between “now” and “overdue” is probably the “next” query that doesn’t give output right now
Yes seems that way:
