I imported a file called 2022_10_08.journal.md
into LogSeq, by dragging it into the pages
directory.
When I view the journal file, the hierarchy navigator is visible. Clicking the parent page (2022_10_08
) also shows the navigator.
But when I visit 2022_10_08
via the Journals tab in the sidebar, the hierarchy navigator isn’t visible. Very strange!
I guess there are two pages for the date, but it’s confusing.
I’m taking a wild guess here, but might be worth a try for you
I have folders called pages and also ones called journals.
Maybe try dropping your file into the journals folder instead?
Good luck
I tried that, no dice unfortunately. I think that’s because the journal page is meant to be 2022_01_01.md
or whatever but my page is called 2022_01_01.sometitle.md
