Yes: https://docs.logseq.com/#/page/6526bd80-9776-405e-b726-d6d1633d1606
- Exercises
- What operator should you use when you want to see results that contain either of two search terms?
- OR
- What operator should you use when you only want to see results that contain both of two search terms?
- AND
- What operator should you use when you only want to see results that contain one search term but do not contain another search term
- NOT
- True or False: given the following query, all blocks containing the link
[[Hamlet]]will show in the results.
a.[[Hamlet]] OR [[Shakespeare]]- True
- It will query all blocks that contains Hamlet and that contains Shakespeare
- True
[[Ghosts]]will show in the results.
a.[[Ghosts]] NOT [[Shakespeare]]- False
- It will hide results that contains Ghosts and Shakespeare at the same time
- False
[[Sharespeare]]will show in the results.a. ``[[Shakespeare]] AND ([[Hamlet]] NOT [[Ghosts]])- False
- It will hide results that contains Shakespeare that doesn’t contain Hamlet and contains Ghosts
- False
