Logseq DB - Changelog
Changelog from: 2025-05-13 to: 2025-05-18
New Feature
  • Add native datepicker for journals in capacitor-new (ed8e7d9da)
  • Enhance db graph query function to support lookup by property ident (046a59312)
Enhancement
  • Improve config.edn for new db graphs by removing file graph keys and comments (dda13d61b)
  • Enable counts for linked references to provide better overview in filters (120730a8d)
  • Add import option to allow existing pages to keep their properties (bd115eef0)
  • Enhance CLI built db graphs to have same config.edn as UI ones (f896a774e)
  • Show block breadcrumbs on header and in cmdk/node reference (568db4a75)
  • Save only namespaced pages to Library (5f547a4e1)
Bug Fix
  • Fix pages displayed as invalid ref in table view (09b333a5c)
  • Resolve issue where can’t switch to another graph if current one failed to open (12c6928ba)
  • Fix export of invalid keywords in graph exports (1f685deff)
  • Resolve app failing on creating properties due to cljs conditional checks (edae0853a)
Chore
  • Remove deprecated dependencies from removed slides (637955cf1)
  • Update comments and aliases for consistency in deps.edn files (1d8869a4a)
  • Remove unused dep from capacitor-file-sync and capacitor fs (0d99eea39)
Performance
  • Upgrade better-sqlite3 to match node bump for test stability (dc0e22498)
Refactoring
  • Ensure all ::sqlite-export keys aren’t passed to sqlite.build for cleaner code (c308e04b9)
  • Move :block/title to page-or-block-attrs (reverted due to test failures) (a02e842ea)
Changelog from: 2025-05-18 to: 2025-05-26
New Features
  • Capacitor: Added login modal page. (b938086c9)
  • Block Manipulation: Implemented block zoom in functionality. (5f1de13b2)
  • Mobile Editing: Added support for swipe to select blocks, preventing scroll. (f4e49a4b1)
  • Search: Improved search functionality in the application (c9044afb3)
Enhancements
  • Capacitor Mobile UX: Numerous improvements to the mobile user experience, including login modals, navigation tabs, block editing, and styles. (93b959987, eb2bf614f, 97f917a17, 582ac7695)
  • Property Editing: Improved tag properties with select functionality. (65f5b9cd6)
  • Sidebar Navigation: Enhanced sidebar navigation with mod+j support for block manipulation and search access. (fb1d38bc6)
  • Mobile Bar: Reused the mobile bar component throughout the Capacitor app to ensure consistency and improve maintainability. (eb2bf614f)
  • Graph Selection: The Switch Graph functionality has been improved in capacitor. (03de1aed5)
  • Property Configuration: Added ability to configure a property and delete it through the table header on mobile. (4ef77e3a3)
Bug Fixes
  • Capacitor Navigation: Resolved issues with navigation tabs on Android devices. (1e5ae97a1)
  • Block Alignment: Fixed an issue related to block alignment bugs within logseq. (0a65f7d6a)
  • Property Validation: Addresses issues where invalid properties were added and breaking app state. (4b39ce213)
  • Graph Import Errors: Resolved a bug with graphs importing and merging when using the property classes option. (471889729)
  • Keyboard Input: Fixed an issue where the system keyboard would flicker or hide during block editing on mobile. (146c04fcc)
  • Property Popup Issues: Corrected problems with double popups when selecting properties in the UI. (d666d1ddf)
Performance Improvements
  • File Parsing Performance: Refactored file parsing logic to improve performance by moving it to a worker thread. (See upstream/refactor/move-file-parse-to-worker)
  • Slow Editing Fix: Addressed a performance bottleneck that was causing slowdowns during file editing. (ed32cfb4c)
Refactoring
  • Page Parent Refactor: Cleaned up code related to page parent management, improving robustness and handling of converted tags. (See upstream/refactor/page-parent)
  • Dev Command Cleanup: Simplified dev commands that were incorrectly appearing in the command list (62aa8c55a)
Chore & Dependencies Updates
  • Electron Downgrade: Temporarily downgraded Electron and Better SQLite to resolve build issues.(b419ff0dc)
  • Babel Dependency Upgrade: Updated Babel runtime and helpers. (8bfb0c91d, e2694bbae)
  • Vite Dependency Upgrade: Updated Vite packages in the project (08287c411)
Changelog from: 2025-05-26 to: 2025-05-31
Spotlight
  • Logseq DB git branch feat\db merged to master with 7322 commits :tada:
    • What does this mean?
      • Same app to work with Logseq DB graph and MD
      • Improved UI now available on MD graph
      • Improved security with dependency upgrades (node.js, electron…)
      • Performance improvement across the board.
    • Notable changes
      • The slide feature is disabled
    • Area of improvement
      • Plugins should have some minor adjustment from plugin developers
      • Potential unknown bugs(your feedback will be greatly appreciated)
New Features
  • Mobile: Added native inline calendar for iOS devices. (44cbbd0c)
  • Mobile: Added login state management for mobile apps (b37ca0c1)
Enhancements
  • Sync: Enhanced network status synchronization to the worker process. (5384ec06)
  • Search: Improved search functionality with support for recent search history and updates. (26113f47)
  • Address Suggestions: Added address suggestions from Gabriel and Zhiyuan. (a2cf44dc)
  • UI: Moved the sync indicator to the right side of the screen. (8a35115e)
Bug Fixes
Database & Data Management
  • Fixed an issue where deleting addresses could lead to problems with ref-counting. (db100235)
  • Fixed a regression in the query builder affecting multiple property types, including checkboxes. (04190d22)
  • Fixed a sorting issue with the :date property in table views. (a4747903)
  • Enhanced garbage collection to remove unused addresses and retain only referenced entries. (b60df1fcad)
Real-Time Collaboration (RTC)
  • Fixed an issue where duplicate blocks were created for new journal pages during RTC. (66237f1c)
  • Addressed duplicate block ID creation during RTC synchronization. (4f6c0fee)
User Interface (UI)
  • Fixed an issue where the add button was not displayed correctly. (b37ca0c1)
  • Fixed a bug where #Task was added to blocks incorrectly during status/deadline modifications. (8a5e38af)
  • Fixed issue causing problems with publishing due to :block/tags (06b43ba5)
  • Fixed alias reference display issues (d78bd644)
General Fixes
  • Fixed reference inheritance issues in page filters. (b14696f8)
  • Fixed an issue with extracted block IDs. (4ed15c7d)
Refactoring
  • Code Quality: Addressed and resolved various linting issues across the codebase. (ce791172)
Chore
  • Updated documentation links and removed feat/db mentions. (ac975766)
  • Removed unused files from the project. (f9934c7c)
Performance
  • Increased test data to 1,000,000 datoms (5a705911)
Changelog from: 2025-05-31 to: 2025-06-07
New Feature
  • Add a command to GC current graph and schedule regular garbage collection runs. (ad190a0f3)
  • Upgrade pdfjs in the development environment.(84183068f)
  • Implement a dark theme for mobile (iOS). (52cd74461)
  • Add native inline calendar on iOS devices.(44cbbd0c8)
Enhancement
  • Put pages before blocks in autocomplete suggestions for improved UX. (20ec61641)
  • Show editor popups at the top left corner of the screen.(184add530)
  • Enhance mobile UX by displaying downloading modals and using smaller font sizes for graph names. (dbc2064dc, fe5bf6cc0)
  • Sync system theme mode for improved mobile experience (d3c15abf1).
Bug Fix
  • Fix: Error when using an outdated frontend incompatible with the database graph version.(ba168f077)
  • Prevent duplicated first blocks from being created for new journal pages during real time collaboration (8eee397b4).
  • Fix block reference display in table view on initial load.(96028fa6d)
  • Correct page properties functionality for hide empty, hide by default and ui position. (75104470a).
  • Fix issue where deleting blocks in containers moved the cursor to another container.( f7035a026)
  • Resolve crash related to linked references on mobile with a large number of refs (000d9aee0).
  • Fix issue where text overlapped for Deadline and Scheduled properties (e21ae5a52)
  • Resolve a crash in the table view.(c4e4e28be).
  • Fixes issue with pdf viewer opening and asset loading during publishing (69fce60cf, ea6d2678f).
  • Fix issue preventing keyboard from re-opening when editing another block on mobile (b9290b81b)
Chore
Performance
  • Unmount journals when searching in the capacitor new build for improved performance.(f40a4a9bb).
  • Defer loading more scripts during publishing (56e8a298b)
Refactoring
  • Collect :graph-git-sha when missing addresses to streamline address handling.(4f72220b7)
Logseq Changelog (2025-06-07 to 2025-06-18)
Spotlight
The Library implementation enables page management capabilities via an automatically collection of namespace pages, which makes building hierarchy structures easier. This change also comes with the renaming of the property: Parent to Extends.
Demo: Library demo | Loom
New Feature
Library Feature
  • Library page implementation with page management capabilities (c209d577c)
  • Ability to create pages directly on Library (f442ae82a)
  • Ability to move existing pages to Library (b348b031e)
  • Ability to delete pages from Library (ed42ae17b)
  • List pages only on the Library page (edfd02027)
  • Add pages to the bottom of Library page (3fc6710f0)
Import & Export Features
Task Management
  • Reset both scheduled and deadline for repeat tasks when done (6b39fdaaf)
Enhancement
User Experience
  • More intuitive UX for tag properties with vertical display and descriptions (cada17252)
  • Show configure tag instead of create tag when exists (25bd22522)
  • CMDK tag configure (1d3e8a170)
  • Convert existing page to a tag when tagging a block (e92ea7a77)
  • Render blocks by their orders (3b718f70c)
  • Display parent page when referencing a page (68640cb4e)
  • Show border for repeat task settings (84da22b2b)
  • Use yyyymmdd to search journals (3bdd46a89)
  • Set initial height for pictures (f4f15c251)
  • Preload children references when loading a block (7d8be5107)
  • Don’t show child page properties on Library (266369471)
Mobile Improvements
Performance & Data Management
  • Transfer bytes when sending data from worker to UI (4bef3c68b)
  • Export SQLite every 30 seconds and run VACUUM when GC (018f954af)
  • Update remote-function (706c859ed)
Plugin & API Improvements
Import & Asset Handling
  • Import asset metadata with metadata display to user (4524fc837)
  • Import assets handles unused assets and existing assets (f318d6853)
  • Put library page name to config to make it easier to rename (53e0d1a4c)
Bug Fix
Core Functionality
  • Able to convert an existing page to a property (88216d299)
  • Load all user datoms when opening a graph (54a82f38c)
  • Task status in references are not loaded when rendering (e09b8ca97)
  • Tag properties migration (e5a75db04)
  • Block/tags are not displayed on table view (015819481)
  • Migrate for using properties as tags (170b0a9a8)
  • Missing db/ident for inline tags (9bb6842b1)
  • Remove :block/order for tags (785e5b320)
User Interface
Property System
  • Don’t popup property config when cmd+click the property title (6fec5f1c1)
  • Disallow classes as properties (1fe835e56, 73db9a2ac)
  • Property? should not treat classes as properties (2e19702af)
  • Migrated properties not migrating :logseq.property/type (b48dfce55)
  • Add migration to separate properties from classes (096c47465)
  • Some properties may not have index (47ccc9e90)
  • Bulk set property with type checkbox (691f5534a)
Task & Repeat System
  • Task sort by scheduled field make empty rows disappeared (1cac99d0c)
  • Wrong interval for repeat tasks (83a281c78)
  • Ensure future time when reschedule a task (956330f9f)
  • Set next repeat time based on the time user has picked (e7480b6f2)
  • Set recur frequency default to 1 if it’s empty (2acf40a56)
  • Applying a template to the Journal tag removes it (b1ee3f5a5)
Editor & Content
  • Block content (Icon + Text) misaligned (692b518a4)
  • Limit image width (51a93051b)
  • Moving the focus up and down doesn’t work properly (47cc2c998)
  • Disable annoying node preview when editing (f7fe81441)
  • Click a link in node reference opens the node (dcc2e9d37)
  • Don’t highlight datetime property value when hovering the value (1ea936eca)
Query & References
  • Filters not work for linked references (be66270a4)
  • No child block inheritance from parent blocks when filtering (9f50aca90, 3cbdcfc1b)
  • Query tables not rendering contents on app start up (6551c9ba9)
  • Edit query button move around left and right side (a6bd17547)
Flashcards & Learning
  • Flashcard review showing blank after one or two cards (8994647dc)
  • Card modal blink when switching to the next card (f9cf6adcf)
  • Card doesn’t change after reviewed (0a0612fe6)
Links & Pages
Platform & Cross-platform
  • Use fs.renameSync instead of shell commands for cross-platform file move (bb71aa9ba)
  • Replace ‘mv’ with cross-platform compatible file move in gulpfile.js (f9d6b77b5)
Mobile-specific
Plugin API
  • :logseq.Editor.getBlock error when includeChildren is true (d6dae4d92)
  • Upsert block property (0ebff0105)
Import/Asset Handling
  • Importing assets for more complex blocks like paragraphs with links (501063e62)
  • Importing assets in subdirectories (bb31c4e6f)
  • CLI import not copying assets to correct location (3fa32ae99)
Real-time Collaboration
  • Keep online-users info when reuse same WebSocket (2e1bbd839)
  • Missing create-by-ref (e5a441783)
  • Repo has wrong graph-schema-version in all-repos (d6a96e825)
Chore
Maintenance
Testing
Test Infrastructure
Test Fixes
Refactoring
Code Organization
  • Move reference fns to logseq.db.common.reference (be66270a4)
  • Rename :block.temp/fully-loaded? to :block.temp/load-status (3b718f70c)
  • Remove buggy parent cycle detect (3b718f70c)
Changelog (2025-06-18 to 2025-07-05)
New Feature
Page and Block Management
  • Added page-block conversion functionality with #Page tag support (2f78ca8, 5f4fa3b) ==> (to be merged soon for alpha testing)
  • Implemented move blocks feature via cmd+k (dc9f714)
  • Added support for importing page and block embeds (507ff3c)
  • Enhanced import functionality for markdown quotes with #Quote support (5b4f43d, 8c6146a)
Tag System
  • Added extends support for multiple tags with cycle validation (cc39c1c, 9c49f63)
  • Implemented “p t” keyboard shortcut to set tags for selected blocks (9ea2826)
Mobile Platform
  • Introduced new mobile application with enhanced UI and performance optimizations (8de6681, 48da90f)
Enhancement
  • Optimized linked references performance by avoiding recursive rules and using block/path-ref (d8a07234)
  • Implemented virtualized lists for blocks and grouped results by default (6f4e8cc, 76a8f8c)
  • Reduced get-block calls when children have been loaded (119485f, b6c06b6)
  • Improved sort view data performance using datoms when possible (0047730)
  • Lazy rendering of references and DOM node recycling when folding (6c14572, 82e3589)
  • Avoided re-running built-in queries when collapsed (33331cc)
User Experience
  • Enhanced block selection with visible add button improvements (a97e7ff, afc36f4)
  • Improved image asset UX with dots menu for actions (6dca6de, 71cdd4a)
  • Don’t clear input after adding a page to Library (2708743)
  • Separated delete local graph and remote graph options (73fdd87)
  • Updated “p a” to toggle displaying all properties including hidden ones (9ea2826)
  • Renamed ‘All pages’ to ‘Pages’ for consistency with other sidebar items (a7562d7)
Import System
  • Enhanced import to support classes and properties from multiple namespaces (16ac807)
  • Improved AST block handling for query conversions (58d3abb, cc05518)
Developer Tools
  • Added CLI support for exporting different types and diffing exports (0cb5c99, 32a29f5)
  • Enhanced schema CLI with optional export functionality (b6cb124)
  • Added tests for unique namespaced pages and graph validations (4b5305e)
Plugin System
  • Improved plugin APIs for block properties with better validation (87474891, 69b779e)
  • Enhanced get db indent from plugin caller (3a66ea8)
Bug Fix
Block and Page Management
  • Fixed block could be converted to page creating invalid nodes (8b08d0f)
  • Fixed blocks to #Page allowing invalid titles (7f82448)
  • Fixed built-in pages being turned into tags (e489cc2, b22e5af)
  • Fixed delete at end concatenating wrong blocks (19513d3)
  • Fixed indentation after embedded node (a365154)
  • Fixed can’t edit blocks on tags (c8e869d)
  • Fixed lost editor focus when indenting to embed node (a63d21c)
Import and Export
  • Fixed import property changes from :node to :default on same page (42f0519)
  • Fixed import not handling scheduled and deadline property on same block (fdff75c)
  • Fixed import fails on query sort with built-in properties (957eab7)
  • Fixed :block/alias not exported with :page export (0f3957a)
  • Fixed failed to export EDN because default value property referenced (7037a84)
Database and Validation
  • Fixed batch delete tags breaking pages (48adb27)
  • Fixed batch remove required property resulting in invalid entities (39e2967)
  • Fixed unset property breaking system nodes/pages (cbfe855)
  • Fixed delete default property values when deleting blocks (bbbb2f3)
  • Fixed URL type validation and unknown error in db validations (c770c91)
  • Fixed tags having duplicate names (e4ffd13)
User Interface
  • Fixed tag completion showing 2 entries for existing tag (b940138)
  • Fixed number value not saved when redirecting to another page (04d3d02)
  • Fixed pressing ESC while typing Chinese losing cursor (3e8d0f0)
  • Fixed breadcrumb inline display issues (1e59e8e, df9f64b)
  • Fixed display tweet macro instead of embed in table view (9209118)
  • Fixed images in table view and asset display in property values (1aa21ec, d14cfb0)
File Handling
  • Fixed uploaded file cannot be opened in file graphs (e73caeb)
  • Fixed asset links with regex characters not getting updated (7968058)
  • Fixed open asset file with default app on Electron (ff2ebe3)
  • Fixed assets referenced in blocks not loading correctly on initial graph load (477029d)
Search and Queries
  • Fixed building search index shouldn’t be blocked by one block (b5f0a4d)
  • Fixed graph view issues (ac019a2)
Mobile Platform
  • Fixed popup auto-close for /scheduled and /deadline (8de6681)
  • Fixed set property value doesn’t close popup (33b5da8)
  • Fixed status bar color for Android platform (1f63233)
Performance
Memory and Rendering
  • Implemented lazy rendering of references to improve page load times (6c14572)
  • Optimized get-class-extends performance (2023d87)
  • Fixed slow scrolling on 40k all pages (7b5e545)
Refactoring
Code Organization
  • Renamed sqlite.build :build/class-parent to :build/class-extends (268889d)
  • Simplified web assets path and removed sync static files (be6be68, 32d70b2)
  • Replaced capacitor references with mobile (9a7d43d)
Database Schema
  • Updated schema.org JSON file to latest version 29.2 with 19 new tags and 48 properties (d63a5ff)
Chore
Dependencies and Build
  • Bumped pbkdf2 from 3.1.2 to 3.1.3 in /packages/tldraw (e209a65)
  • Fixed test build can’t be watched with shadow-cljs upgrade (1b3a9cd)
Code Maintenance
  • Fixed wording in messages for better grammar (33464da)
  • Removed dev flags and image placeholders (9f924dd, f848889)
  • Enhanced migrate fixes to be pure functions (dfa428c)
Testing
  • Added comprehensive e2e tests for page-block conversion and move functionality (74036e2, b44292d)
  • Added tag-basic tests and property-related e2e tests (665a5a3, f818491)
Thanks to Contributors
Changelog (2025-07-04 to 2025-07-30)
:tada: New Features
Mobile Support
  • Launch new mobile app with Capacitor framework (9c83237)
    • Replaces previous Ionic implementation with improved performance
    • Enables database graphs and RTC sync on mobile devices
    • Supports iOS and Android platforms
Quick Add
  • Add Quick Add feature for rapid block creation (e259be0, f2bf7e3)
    • Auto-opens block for editing in quick add mode
    • Shows notification after successful quick add
    • Includes migration for quick add page
Command Line Interface (CLI)
  • Introduce Logseq CLI for command-line operations (1e64fed)
    • List command to show all local DB graphs
    • Show command to display graph metadata and git SHA
    • Query command with optional API support for Datalog queries
    • Search command with highlighting and customizable result limits
    • Export EDN command for graph data extraction
    • Support for multiple graphs in show command
    • Includes --version flag and comprehensive help system
Graph Management
  • Enable uploading local graphs to server for sync (c86885a)
    • Allows converting local graphs to remote graphs
    • Supports seamless transition between local and cloud storage
PDF Annotation Import
  • Import PDF text and area annotations from edn files (536f39c, 4c9d063)
    • Supports both text highlights and area selections
    • Preserves annotation metadata and positioning
:sparkles: Enhancements
Mobile UI/UX
  • Improve mobile block editing experience (4f47856)
    • Fix editing content not saved when closing keyboard quickly
    • Enable multiple blocks dragging on mobile (01ee6a1)
    • Add sync button to restart RTC on mobile (563b185)
Search & Navigation
  • Don’t show block breadcrumbs on header for cleaner UI (44f9d8a)
    • Only display page parents in header
    • Reduces visual clutter
Developer Experience
  • Add src/main/mobile to separate linter (cd65517)
    • Prevents file graph code from entering mobile app
    • Enforces cleaner architecture boundaries
Performance
  • Disable journal blocks virtualization to improve scroll performance (2c47b92)
  • Use skeleton loading instead of spinner for better perceived performance (791bfe5)
:bug: Bug Fixes
Mobile-specific Fixes
  • Fix block control not displayed initially when collapsed (d2827ed)
  • Fix floating cursor when presenting quick add (879c3ce)
  • Fix mobile tags not being displayed (e98e993)
  • Fix blank graph name on mobile (c012941)
  • Fix sync indicator click not showing popup (6d91359)
File Handling
  • Fix local file paths not working on MD and DB graphs (3773674)
  • Fix math equations display issues (2c13bce)
  • Fix KaTeX assets path issues (e76e3ee)
Property System
  • Fix :number property values not deletable in table view (45709f9)
  • Fix “icon::” property not working for file graphs (4caa79a)
  • Fix deleting last extends value not reverting to Root (09e60ae)
RTC & Sync
  • Fix RTC indicator status updates (a9a6bce)
  • Ensure assets synced using push-asset-block-updates messages (bbe8f89)
  • Fix :client/schema empty for class-block (b4b375f)
Publishing
  • Fix publishing app showing repo switcher (adbac92)
  • Fix published file graph loading bugs (e0632f0)
  • Fix login button in publishing (af1283a)
Editor
  • Fix cursor position bug in code blocks (6e9864a)
  • Fix display reference preview in editing mode (9d7856d)
  • Fix backlinks context for file graphs (4455dfc)
API
  • Fix API query method and error handling (9874615)
  • Fix incorrect lowercase for qualified property key (e489e93)
  • Fix incorrect db namespace for HTTP API calls (2d1436a)
:wrench: Chores
Build & Infrastructure
  • Fix GitHub workflows missing dependencies (6924223)
  • Update checkout action versions (1616c63)
  • Move sanitize-filename into exporter module (6ef1c62)
Mobile Development
  • Disable SSL config for iOS development (73b5cd1)
  • Add RTC test group (9abe686)
  • Update splash screen (54abd62)
:blue_heart: Thanks to Contributors
Changelog (2025-07-30 to 2025-08-22)
Spotlight
This release delivers three major initiatives that significantly expand Logseq’s capabilities:
  • Mobile Experience Overhaul - Complete redesign of the mobile interface, replacing Ionic with a custom Silk framework. This brings improved navigation, better touch interactions, and enhanced performance across iOS and Android platforms.
    Semantic Search - Introduction of local AI-powered semantic search using embedding models and HNSWLIB. Users can now search by meaning and context, not just keywords, with hybrid search combining traditional and semantic results.
  • Logseq CLI - New command-line interface offering offline search, graph querying, data export, and graph management capabilities. Developers and power users can now interact with Logseq graphs programmatically.
Reminder
  • Logseq DB (local first) is in open alpha phase
    • Anyone can test it on:
      • Browser: https://test.logseq.com (the graph stays locally on your machine)
      • Desktop: Windows, Linux and macOS desktop builds available
  • Logseq DB is in closed alpha testing phase with a small group of users:
    • Logseq DB mobile - on IOS first. Android will come later
    • Logseq DB realtime collaboration
      • which enables:
        • On devices
          • Sync of the DB graph between Web/browser <==> Desktop <==> Logseq DB Mobile
        • For Users
          • Real time collaboration between Logseq DB user on any devices
      • For the RTC test, please fill out this form: https://forms.gle/YSyF4WfKPSDuwyjH6
  • Documentation
New Feature
  • Search and Queries
    • Add semantic search with local embedding models and HNSWLIB integration (a2eee34d8)
    • Add offline CLI search and predefined query functionality (50325ff7f)
  • Block Editing and Management
    • Add support for converting blocks to pages and vice versa using #Page tag (d84d3f965)
    • Add “p t” keyboard shortcut to set tags for selected blocks (d84d3f965)
    • Add cmd+k move blocks functionality (d84d3f965)
  • Database Operations
    • Add group sorting functionality for views with configurable sort properties (36de5397e)
    • Add ability to filter by empty and not empty values in table views (12e1f35cc)
  • Developer Tools
    • Add comprehensive CLI with list, show, query, search, and export commands (887d91d2a)
Enhancement
  • Mobile Support
    • Complete mobile UI overhaul replacing Ionic with custom Silk framework (0ecae62ce)
    • Add swipe navigation and improved sheet handling for mobile interface (b2ca3fcc0)
    • Add swipe-from-edge gesture to open sidebar (41cb83e3e)
    • Improve mobile status bar styling and safe area handling (52aba7aa0)
  • UI/UX Improvements
    • Show edit button instead of 00:00 for datetime properties (a918e5b6f)
    • Reserve add-button visibility when editing blocks (cd9d49cdc)
    • Smooth sidebar closing animation (1f14b3cc4)
  • Performance
    • Use shared worker for inference to reduce memory usage (1e84a2104)
    • Optimize semantic search embedding with batch processing and stale check improvements (3faee9cc7)
    • Improve performance for large graphs with local embedding enabled (061528d08)
    • Add hybrid keyword and semantic search with configurable weights (a2eee34d8)
    • Display WebGPU compatibility warning when not supported (1cccba390)
Bug Fix
  • File Handling
    • Fix PDF re-upload functionality with asset validation (35a089ce5)
    • Fix video assets playback issues on desktop app (de67a46e9)
    • Fix macros not rendering in property values and views (fe93a3156)
  • Mobile Support
    • Fix mobile keyboard issues with quick add and editing modes (1a09e2a98)
    • Fix mobile clipboard functionality (63e4948f7)
    • Fix page tags not displaying on iOS page view (25b0e25d4)
    • Fix mobile sidebar and navigation issues (6cbf459f8)
    • Fix page references with same name in one block (8c402676a)
    • Fix block ordering and validation issues (27c3cd3b2)
    • Prevent block moves to invalid parent locations (abbc30262)
    • Fix application crash when populating node properties (c9e446fd8)
    • Fix datetime filter rows incorrectly filtering empty values (921d81549)
    • Fix table view regression in file graph mode (0bfb458d9)
    • Fix checkbox property value alignment (3025c94d2)
    • Fix page blink when inserting blocks in zoom mode (8f29bc17d)
    • Fix quick add focus and editing mode issues (5dd9fc0d0)
Chore
  • Developer Tools
    • Bump Electron to version 37 with corresponding Node.js version update (1d9fa6929)
    • Update to offic@sql@sqlite.orgte.orgal @sqlite.org/sqlite-wasm replacing fork (11eb0f38a)
    • Add comprehensive GitHub Actions workflow improvements (d65f81ef0)
    • Fix CLI start time optimization and namespace lazy loading (3ae3ff2cd)
    • Add CLI linting workflows and configuration (f86a7558c)
    • Fix publishing and build system issues (182a51a85)
    • Upgrade dependency packages and security updates (ab61a3043)
    • Remove mobile static files from test website (11514a0c3)
    • Add database validation and asset checksum improvements (7685760af)
Thanks to Contri@Alejandroutors@Alejandro
Changelog (2025-08-22 to 2025-09-06)
New Feature
CLI & API
Query System
  • Add :self-ref rule for improved page reference queries (fa7cd0719)
  • Fix :and ref queries to return nodes with at least one reference (fa7cd0719)
Enhancement
Mobile Experience
  • Improve mobile sidebar navigation with sheet-based UI (51e62b003)
  • Remove need to swipe from edge for navigation (6d4bc92ca)
  • Add safe area insets for better iOS and Android layout (687d3e8ca, 0a4f5b9a0)
  • Enhance search with auto-focus and improved scrolling (cba8520ed, 96b52e3c2)
  • Increase font sizes for graph switch and sidebar (9313235d1)
  • Toggle sidebar without releasing touch (3073649b9)
User Experience
  • Improve slash commands sorting for priority items (760cf625f)
  • Move graph view to bottom of navigation by default (a92b49c8e)
  • Increase size for page title positioned property icons (2cf9a6c61)
  • Display humanized error messages when downloading RTC graph (ce933b3c3)
  • Add low memory detection and handling (2704becc6)
Development Tools
  • Improve shadow-cljs initial load time (a59b76bb5)
  • Add CLI usage descriptions and better error handling (4b5a16628, c0bee994c)
  • Upgrade Java version to 21 for Android builds (0e87f9e19)
Performance
Memory Optimization
  • Add weak references to reduce memory usage (2aee65854)
  • Optimize memory pressure during RTC graph downloads (4c2428f85)
  • Remove redundant computations in database operations (d05be857f, 290124d66)
  • Faster block references rebuilding (1974f696a)
Database Performance
  • Skip pipeline calculations for RTC initial downloads (248d8c33f)
  • Remove usage of memoization for better performance (3ffb5968c)
  • Don’t cache entities that reference the database (4186bb073)
Bug Fix
  • Fix deleting nodes incorrectly moving properties to previous block (5846e0544)
  • Fix math node rendering issues on desktop (2e9b6c18b)
  • Fix math mode brackets rendering incorrectly (b0ddf838e)
  • Fix triangle for opening/closing children disappearing after editing (b2e700b3d)
  • Fix clicking indentation lines not working recursively (c00460a97)
  • Fix toggle open all blocks functionality (be2977dd4)
  • Fix page creation with same name when namespace exists (063aec02a)
  • Fix navigation after deleting focused node (3888559b9)
Query and Search Issues
  • Fix DSL showing UUID instead of title (eed6224fc)
  • Fix hidden properties appearing in query results (4b0ea7d0c)
  • Don’t show matched children blocks in view results (6c3e3c344)
  • Fix references not being calculated correctly (77c741227)
  • Fix page sorting by backlinks count (b2034753a)
UI and Display Fixes
  • Fix sticky header issues with multiple tables (8a862b7a0)
  • Fix property value selection and popup behavior (b39927503, eb2ae991b)
  • Fix positioned properties showing in table row popup (90fa1112f)
  • Fix datetime values not showing when journal pages don’t exist (4b680bb73)
  • Center align number property values (e4cb1d320)
  • Fix popup scrolling issues (7c627db20)
  • Fix action sheet height (3b7be47be)
Mobile-Specific Fixes
  • Fix app reload when database worker closes (43e7eda18)
  • Fix screen going white when restoring from background (d13357568)
  • Fix iOS share functionality (f44fdeb2e)
  • Fix Android status bar color (53bfcbee7)
  • Fix sharing content between mobile apps (56b54d5f4)
  • Fix sidebar opening during editing or selection (f6de99ea7)
Publishing and Import
  • Fix publishing app not loading with latest changes (dac7ad37a, e9cdb52a3)
  • Fix importing quoted math blocks and lists (a81274cd0)
  • Fix journal references not being built for datetime properties (6ed338b96)
Miscellaneous Fixes
  • Fix list view UI crashes when clicking add button (3ff06e5a1)
  • Fix tweet embed functionality (afdf00ed2)
  • Fix PostHog initialization (cee1572ac)
  • Fix web platform detection (59f75319b)
  • Fix file graphs showing on both web and mobile (cfbb563bc)
  • Fix page reference saving in quick capture (0696a556d)
Refactoring
Code Structure
  • Remove block/path-refs in favor of :block/refs and has-ref rule (248d8c33f)
  • Use webpack only for workers (abe03fdac)
  • Remove usages of get-all-defined-kw->config macro (92ed69215)
  • Use immutable db-after value in fix-page-tags (8405b24f8)
  • Apply review.md recommendations across codebase (290124d66)
Chore
  • Bump Electron from 37.2.6 to 37.3.1 (6800b0cf4)
  • Update to latest nbb with DataScript updates (f93f889f8)
  • Update logseq/datascript dependency (ceb1603a1)
  • Fix asset-path in ClojureScript mobile watch command (8bc154b0c)
Development and Testing
Changelog (2025-09-06 to 2025-09-27)
Spotlight
Four major initiatives that significantly expand Logseq’s capabilities and user experience:
  • Mobile Audio Recording & Transcription - Complete integration of audio recording with live waveform visualization and automatic speech-to-text transcription. iOS users can now record voice notes with the new speech API, while Android supports high-quality WAV recording. Audio transcriptions are automatically saved as child blocks.
  • iOS Ecosystem Integration - Deep iOS integration, including home screen widgets, shortcuts, and quick actions. Users can now capture thoughts instantly from the lock screen, home screen widgets, or through Siri shortcuts, without needing to open the app.
  • MCP Server for AI Integration - Introduction of Model Context Protocol (MCP) server functionality enabling AI agents and language models to interact directly with Logseq graphs. This includes tools for reading pages, searching blocks, updating content, and managing graph data programmatically, opening new possibilities for AI-assisted knowledge work.
  • Enhanced Mobile Experience - Comprehensive mobile UI improvements, including better navigation, refined keyboard handling, improved block editing in sheets, and platform-specific optimizations for both iOS and Android.
New Feature
Audio recording and transcription
  • Add comprehensive mobile audio recording with waveform visualization (e103593c0)
  • Implement automatic speech transcription for recorded audio (e103593c0)
  • Support offline transcription with punctuation support (e103593c0)
  • Replace wavesurfer with simple-wave-record for better performance (8d00504d8)
  • Add long press + button to start audio recording (b263b1cb8)
iOS platform integration
  • Introduce iOS home screen widgets for quick capture (f90b68258)
  • Add iOS shortcuts support for voice and quick add (b8280d7cb)
  • Implement home screen quick actions for voice and text capture (885974434)
  • Add iOS universal link support (2f23188ac)
MCP server and AI integration
  • Introduce MCP (Model Context Protocol) server for AI agent interaction (1ca8db6c3)
  • Add HTTP streamable mode to MCP server with default enablement (e89fda944)
  • Implement API tools for adding to pages, searching blocks, and updating content (e8b264ab0)
  • Add list tags and properties functionality for MCP server (adc46c2a2)
  • Enable MCP server integration with local graphs via -g option (86d64be88)
  • Add UI setting for toggling MCP server on/off (a3c1e5a5b)
Developer tools
  • Add Linux installer script with desktop integration (0696d51dc)
  • Introduce Windows ARM64 build support (dd50195cc)
Enhancement
Mobile user experience
  • Polish mobile graph selection popup interface (9705f5705)
  • Improve keyboard behavior in block editor modal container (927e84e2b)
  • Auto-detect audio language for transcription (13f510ca0)
  • Enhance navigation with capacitor navigation bar plugin (208bda80e)
User interface improvements
  • Add hidden properties area in sidebar and main page (aba80a456)
  • Polish layout details for file graph editor (ffb4d17f6)
  • Display asset when editing asset title (b14735a0a)
  • Larger logo display on iOS widget (94d0e99cb)
API and plugin system
  • Add fullTitle property and remove temp properties from API (8039054e7)
  • Allow users to store metadata on nodes via :map property (4075c0d50)
  • Enhanced plugin API property handling (2809f7857)
Real-time collaboration
  • Implement RTC operation throttling for better performance (774454dc7)
  • Improve RTC error handling with better exception management (c642dabd3)
  • Add comprehensive RTC logging for debugging (900a0d6da)
Bug Fix
Mobile platform fixes
  • Fix mobile quick add not entering editor mode when app was killed (9c49a4209)
  • Resolve issue where can’t edit code blocks in block sheet (8be834c52)
  • Fix Android graph import functionality (fb295ea7f)
  • Correct Android audio recording mimeType for web platform (fef16ba03)
Core functionality fixes
  • Fix images uploaded on other pages being added to today page (9c92fbecc)
  • Resolve repeated tag extends display when referencing tags (2389cf992)
  • Fix date display issue showing “Today’s date” as “Yesterday” (467952872)
  • Correct block references with missing icons (3a6970567)
Editor and navigation fixes
  • Fix quick add shortcut not opening block for editing (e61a398d9)
  • Resolve clicking tabs jumping to top issue (a46bae3ac)
  • Fix backspace behavior preserving properties when appropriate (abd1d070f)
  • Correct page node movement up/down functionality (9bb246bc2)
Database and synchronization
  • Fix database worker status detection using sqlite transaction changes (9f21cb133)
  • Ensure UI database updates before resolving remote transactions (98418bb57)
  • Resolve block path-refs removal during database migration (42dc6ca6f)
Performance
Bundle and build optimization
  • Reduce bundle size using webpack production mode (f6d56cca7)
  • Limit asset size to 100MB for app uploads (22a09ca77)
  • Optimize video size limitations (aef16cbae)
Audio processing
  • Set waveform visualization window to 5 seconds for better performance (335b275e0)
  • Limit audio recording length for optimal performance (2517d1509)
  • Fix media recorder timeslice configuration (c39f83ed7)
Database operations
  • Use promise channels to await database transactions (c1b0c583e)
  • Implement delay yielding for UI database updates (3729b88a1)
Refactoring
Code organization
  • Move database graph page operations to outliner dependency (20a477c35)
  • Refactor filesystem operations to database worker (1a9b5b843)
  • Remove deprecated frontend.db.transact namespace (7a9fc2ccb)
  • Clean up unused navigator.onLine and window.ononline usage (b486bde59)
RTC improvements
  • Reuse database IDs for deleted blocks in undo/redo operations (dd9a32d4d)
  • Merge multiple WebSocket requests into single initialization (655e72ed4)
  • Generate RTC operations from database migrations (fc7729dcb)
Build system improvements
  • Remove unused simple-wave-record build scripts (1d8faf6a3)
  • Clean up development code signing configurations (46325a58b)
  • Move RTC end-to-end tests to clj-e2e (9a55f24ff)
Chore
Dependency management
  • Bump tar-fs from 2.1.1 to 2.1.4 for security (77172fd04)
  • Update cljc-fsrs dependencies (ced070709)
  • Upgrade simple-wave-record dependency (00bf6f44d)
Development environment
  • Update development setup for IntelliJ IDEA/Cursive (9f7cc8e17)
  • Add development documentation for agents and review processes (aa0e15315)
  • Update Xcode to version 26.0.0 for iOS builds (acf49c71e)
CI/CD improvements
  • Fix desktop release CI configuration (59d631b42)
  • Update Windows signing to use Azure Sign (d1c8686b9)
  • Remove outdated code signing configurations (bee8fd988)
Documentation and cleanup
  • Remove broken Backers section from README (4caf3060a)
  • Remove dead Logseq Hub link (df917f3d5)
  • Clean up compile warnings and lint issues (09aa5901d)
Contributors
Charlie, Gabriel Horner, Kidy Lee, Marc Fargas, Robin Lovelace, Tienson Qin, Tony Cerqui, dependabot[bot], rcmerci
Changelog (2025-09-27 to 2025-10-25)
:glowing_star: Spotlight
This release brings three transformative improvements to Logseq’s developer ecosystem and database reliability:
  • ClojureScript Plugin SDK - Plugin developers can now build plugins using ClojureScript in addition to JavaScript, unlocking the full power of Logseq’s native language for extension development with seamless interop and better type safety.
  • Enhanced Plugin API for Database Graphs - Major refactoring of plugin APIs introduces new methods for working with database graphs, including get_all_tags, get_all_properties, get_tag_objects, comprehensive property management, and improved block manipulation capabilities. Plugin developers should begin testing the updated plugin APIs.
  • Database Validation & Integrity - A Comprehensive database validation system now runs before writes, catching invalid data early and improving graph reliability. Enhanced error reporting to Sentry helps the team identify and fix database issues faster.
New Features
  • ClojureScript Plugin SDK - Add full ClojureScript plugin development support, enabling developers to write plugins in the same language as Logseq’s core (d8809f0)
  • Database Graph APIs - Add get_all_tags, get_all_properties, and get_tag_objects APIs for comprehensive graph querying (4800ed2)
  • Import EDN Undo/Redo - Imported EDN data now supports undo and redo operations with proper UI refresh (fe619d3, 487cbb2)
Enhancements
PDF Experience
  • Save zoom level preferences between sessions and prevent unwanted zoom resets (584b980)
  • Add reset zoom button to PDF toolbar
  • Support zoom with Cmd/Ctrl + mouse wheel and trackpad pinch gestures
  • Improve conflict resolution and duplicate datom handling (5b9ea85, adfc0a1)
  • Prevent page recreation when properties or tags already exist (f0e80e7)
  • Fix synchronization issues with pages having both #Page and #Tag (cd04cca)
Database Operations
  • Run validation before database writes to catch errors early (b538fe2)
  • Prefer ldb/transact! over d/transact! for better transaction handling (7ed7fb4)
  • Improve database ident validation and error reporting (993381)
  • Collect invalid database errors to Sentry for better debugging (bbc415c)
Plugin System
  • Refactor plugin APIs into separate namespaces for better organization (15de4a8)
  • Enhance get_tag_objects to accept block UUID, db/ident, or title (3962f1f)
  • Add validation when setting block property values (dbd15f7)
  • Add comprehensive E2E tests for plugin APIs (bbb6d8a)
Import System
  • Make import data form operations undo/redoable (487cbb2)
  • Notify users when assets exceed maximum size limits (846f930)
  • Preserve HNSW embeddings during import operations (683b2c5)
UI/UX Improvements
  • Display total reference count when filters are applied (9b3071e)
  • Enhance text auto-spacing for better typography (3b499bc)
  • Keep buttons visible when adding icons or updating views (3f582ec)
Mobile
  • Reload web app if old database worker is still running when switching back (4e5237e)
  • Close Quick Add modal when clicking a block (52a7369)
Bug Fixes
Tags & Properties
  • Fix flashcard queries not showing child tag objects (4cdea72)
  • Fix tag query (tags ...) not returning child tag objects (f3f6c0c)
  • Fix invalid database state when deleting tag objects (aa2ad76)
  • Fix tag title ordering with extends inheritance (9f5b9c3)
  • Fix alias property creating unwanted tags (c03b55b)
  • Fix properties stable sorting and normalize block order (1747e3f)
  • Fix setting block properties with closed values (4249c9e)
PDF Functionality
  • Fix PDF highlighting not working (33354ad)
  • Make PDF title updates easier (2151fad)
Database & Sync
  • Fix invalid database errors when uploading plugins (c32a10e)
  • Skip validation when downloading remote graphs (30a1156)
  • Fix database worker blocking on invalid WebSocket messages (26879cd)
Assets & Import
  • Fix multiple asset upload support (ac14dfd)
  • Prevent out-of-memory errors during asset import by removing byte-array usage (971cec5)
  • Fix invalid asset data during creation (031f2bc)
  • Fix CLI import failures with “Maximum call stack size exceeded” error (2500fe8)
Plugin API
  • Fix get_page_linked_references for plugins (b4c83a7)
  • Fix get_all_pages API implementation (1736691)
  • Fix get_property for plugins (d8c84ae)
  • Fix insert_batch_block to support properties and page UUIDs (87fc95e, e001e12)
  • Fix insertBlock API with properties (caef419)
  • Fix prepend block functionality (3fa1c5c)
  • Fix nil API response causing errors (b4d3fb4)
  • Fix upsert_block_property to support schema (54b6ea9)
UI Issues
  • Fix sidebar not displaying page names under Recent section on Safari (da185db)
  • Fix display of properties with default values that aren’t set yet (bf2d9df)
  • Fix empty button text font size (5618d47)
Linux Installation
  • Fix broken Linux installation with --user option (6b68197)
  • Add uninstall command for Linux
Performance
  • Remove unnecessary d/datom calls for better performance (e1f7d85)
  • Optimize block reference calculation when pasting blocks (d2acb49)
  • Bump Electron to version 38.4.0 (4dc6654)
  • Update dependencies and ClojureScript libraries (4fb291f)
  • Refactor API code organization and separate concerns (df48615)
  • Improve outliner linting rules (bbb8388)
  • Add comprehensive test coverage for properties and tags (a92f286)
Contributors
A huge thank you to everyone who contributed to this release:
@An-Li, @Gabriel-Horner, @Paulo-Bueno, @Tienson-Qin, @charlie, @dependabot, @rcmerci
Changelog (2025-10-26 to 2025-11-15)
Spotlight
This release delivers significant improvements across three key areas that enhance Logseq’s stability, performance, and user experience:
  • Database Migration & Validation - Comprehensive fixes for old database graphs, ensuring data integrity during migrations and preventing invalid data states. Multiple safeguards added to protect built-in properties and handle edge cases in legacy graphs.
  • Performance Optimizations - Major speed improvements for large graphs, with Pages view performance increasing from 1000+ms to 200-300ms for graphs with 40,000 pages. Initial page load times reduced through optimized datom loading and smarter rendering strategies.
  • Mobile Experience Enhancements - Native bottom tabs introduced for iOS, improved touch interactions, and better authentication UI with multilingual support. Mobile-specific fixes for quick capture, search results, and iPad display issues.
New Feature
Plugin System & APIs
  • Add MCP (Model Context Protocol) server support (15a5f29b4)
  • Add plugin class support with ident format plugin.class.id/class-name (0a54e807b)
  • Add comprehensive tag management API functions: create, add, remove, and property management (51fbc705d, 7f4d8ad22)
  • Add development entry support for plugins (501230b0d)
CLI Tools
  • Add import-edn command for both current and local graphs (0bc0892b8)
Authentication
  • Complete authentication UI overhaul with multilingual support (a0a19a91f)
    • New sign-in, sign-up, and password reset flows
    • Password policy validation and tips in multiple languages
    • Countdown timer for code resend functionality
    • Improved mobile login modal styling
Mobile
  • Native bottom tabs on iOS for improved navigation (9ebe370ec)
Enhancement
Performance
  • Massive Pages view optimization: 5x faster for large graphs (1000+ms → 200-300ms for 40k pages) (7b6d6c467, fb271b1d4)
  • Reduce initial datoms that need to be loaded for faster startup (a626cec34)
  • Optimize get-recent-updated-pages query (82a7ec13e)
UI/UX Improvements
  • Add fade-in and delay effects to page reference elements (71a25e612)
  • Display tag hierarchy with parent/child notation (#parent/child) (48fb2b817)
  • Unified node icon rendering for references and embeds (a7c8212df)
  • Show node icons in search results (4c6c3322f)
  • Use dot icon for block nodes (5942c1b98)
  • Display property pairs vertically on mobile for better readability (1662497aa)
  • Set background color for full block instead of just title (b4c4b673e)
  • Render blocks together with parent page for list view (e8fef0d81)
  • Disable breadcrumb redirect in cmd+k results (1bae7b46f)
  • Show settings icon when configuring tags (04dd7a56d)
  • Store image width/height to prevent scroll jank (1fca2a9ff)
  • Keep today queries to avoid scroll junk (4462634f0)
  • Render fewer journals by default for faster initial load (88d9b6e78)
  • Smaller text for card breadcrumbs (409c2c327)
Block Editing
  • Compute diff for block refs instead of resetting all refs when editing (3bc65300b)
Plugin APIs
  • Support custom UUID when creating pages and tags (28bc28ecd, bd4b022a0)
  • set-block-properties! defaults to not reset :many values (94a2d9c28)
  • Export prepend_block_in_page function (025e2e70d)
  • Update error handling for race-failure cases (68c5ab1bc)
Logging
Internationalization
  • Normalize language codes and improve locale handling (a0a19a91f)
Bug Fix
Database & Data Integrity
Built-in Pages & Tags Protection
  • Prevent built-in pages from being converted to tags (3bf78ac5e)
  • Prevent properties from being converted to classes (820b2f075)
  • Disallow updates to protected properties for built-in nodes (e4e838858)
  • Fix more built-in attributes that would cause major bugs if changed (71be8ec3e)
  • Fix some built-in tags shouldn’t be recognized as inline tags (a4ec889a5)
  • Prevent built-in tags like journal from being extended (d8b1feb39)
  • Fix disallowed tags (7619e3ab9)
Block Editing & References
  • Fix refs not rebuilt when applying RTC remote operations (f9cd1acbf)
  • Fix set heading removes refs (fec4f5165)
  • Fix block refs that are hyperlinks unable to be navigated to (de94684d5)
  • Fix can’t deref query result (5e924880b)
  • Remove :block/path-refs entity (12f65c315)
  • Remove :block/level in old graphs (c8c2d780a)
  • Fix block.temp/original-page-name handling (4ebe410e2)
Query System
  • Fix block/order showing up in all block queries (b847cfbcd)
  • Fix timestamps in advanced query not showing (518076d83)
  • Fix query result not showing when :db/id is not specified (7d39b510d)
  • Fix tag and page names collision in query DSL (6f8d2a39f)
  • Don’t show query component when block doesn’t have a query (5e0d52a43)
  • Use UUID instead of name for page ref queries to avoid collisions (d809af8ce)
Mobile Fixes
  • Fix quick capture website on mobile (0ece59542)
  • Fix no bottom tabs and editor bar on iPad (833f59120)
  • Fix failed to open “Import existing notes” on mobile (9ad3da9c6)
  • Fix can’t open block from search result on mobile (5dae9845a)
  • Hide bottom tabs when sheet has been opened (9ebe370ec)
File Import/Export
  • Fix file graph import issues (7dc155b28, 263c499e5)
  • Don’t create new card page when importing file graph (ace82d715)
  • Ensure UI database is full when importing file graph (263c499e5)
  • Fix import of code block inside quote block (c91661f02)
  • Fix wrong rendering of colored quote blocks in markdown graph (9104bebac)
Paste Operations
  • Fix can’t paste asset (2140029c6)
  • Fix can’t undo pasting at empty block (079c8944b)
  • Fix paste query block should create new block (fb9e73593)
  • Fix Cmd+V does not insert images into property value (c5adaddce)
Tag System
  • Fix adding tag property using API produces empty tag (70cf508ec)
  • Fix can’t add node link on tag page with dropdown menu (29cc19203)
  • Fix cmd+k shows configure tag but creates new page (f85546c15)
  • Don’t show parents for children tags in hierarchy (699d3eaf4)
  • Don’t show page’s tags in node references (68548ea2f)
  • Don’t show page’s tags in property values (dcb448d6b)
  • Fix tag dialog issues (3b99f1344)
  • Fix tags rendering (5b35a9ee4)
  • Add PDF annotation to private tags (4046dae5c)
Search
  • Fix search prioritizes creating page over existing library item (3afb112b8)
  • Fix built-in tag/property excluded from semantic search (33ae3f9a0)
UI & Keyboard
  • Fix left arrow does not work properly in property name field (e99f2b6b8)
  • Fix active breadcrumbs in node property dropdown menu (2122d3d27)
  • Use alt+shift+i for go/search-themes on Windows/Linux (085f9093c)
  • Fix virtualized list shouldn’t be nested (f34d58acc)
  • Ensure all elements inline for favorites and recents (84bfd7715)
Plugin & API
  • Fix page refs display UUIDs instead of text for getPage (1ebfd30b5)
  • Fix edit block operation shouldn’t require page ID (dc76a94e0)
  • Fix update :block :add op supported args (e3ce613a7)
  • Convert opts to JS object in insert_block (025e2e70d)
  • Sanitize user property names (0a54e807b)
PDF & Assets
  • Fix can’t delete annotated PDF (76d854660)
Other Fixes
  • Fix YouTube embed (65627d819)
  • Fix + New button error (323674a51)
  • Fix hidden columns display (b7edc5cc9, de0d0cd17)
  • Fix get-fs shouldn’t return nil (2a67e7e45)
  • Fix incorrect descriptions for database graphs (87ad39839)
  • Allow editing block’s other properties if there’s invalid URL (79f670f79)
  • Fix (()) doesn’t work for blocks in file graph (0fe171580)
  • Fix database worker doesn’t need to wait for plugin initialization (5173a73c1)
  • Allow moving non-page blocks to library on UI (46c4f66ae)
  • Don’t run remove-inline-page-classes if save-block doesn’t specify tags (fa86b7955)
  • Export URLs for debug transit (9d2912d1a)
Chore
Dependencies & Build
Testing & CI
  • Add E2E test for nested pages in Library (6844292de)
  • Add RTC E2E tests for page references (5d8c9a4f8)
  • Fix E2E tests (561f422c0)
  • Fix test website CI (1949a8a2f)
  • Fix clj-e2e CI configuration (d25cd4c1e)
  • Prevent deploy when E2E failed (d77ce0593)
  • Disable failing E2E check that prevents deploy (d9cad1260)
  • Re-enable repeatable install (b9318281f)
  • Fix frozen-lockfile install (7bf273874)
  • Fix test from recent tag made private (a3b2ac98f)
  • Fix test’s global change to ldb/transact! (2c6f8101d)
  • Fix pluralization of import/export messages (d7f7dbea1)
Code Quality
Version Management
Contributors
Thank you to all contributors who made this release possible:
@charlie, @Gabriel Horner, @rcmerci, @Tienson Qin
Changelog (2025-11-16 to 2025-12-06)
Spotlight
This release delivers three transformative initiatives that significantly enhance Logseq’s security, mobile experience, and developer tooling:
  • End-to-End Encryption (E2EE) for Real-Time Collaboration - Full implementation of end-to-end encryption for synced graphs, ensuring your collaborative data remains private and secure. E2EE password management is seamlessly integrated with system keychains on both desktop and mobile, includes RSA key-pair generation, AES encryption for graph data and assets, and a “forgot password” recovery option.
  • Native iOS Navigation & Bottom Sheets - Complete redesign of the iOS mobile interface with native UIKit components, replacing the previous web-based Silk framework. This brings smooth native animations, improved gesture handling, dynamic tab system with native bottom sheets, enhanced accessibility with iOS Dynamic Type support, and significantly better performance.
  • Logseq CLI Enhancements - Major improvements to the command-line interface including new validation commands for graph data quality, API mode for export-edn, better error messages for unspecified graphs, and enhanced graph validation with closed-value checking.
New Feature
  • Add end-to-end encryption support for synced graphs with RSA key-pair generation (2b84d729d)
  • Implement “forgot password” setting for E2EE password reset (2b84d729d)
  • Add E2EE settings UI with password confirmation and warnings (0eceffcdb)
  • Enable encryption/decryption for graph uploads, client operations, and assets (abe59cdbf, 09b1fb61f)
  • Support grant-access functionality for encrypted graphs (219d9ad20)
  • Store encrypted E2EE password in system keychain on desktop and mobile (6ed01dfb9, 4593ab3d7)
Mobile Experience
  • Implement native navigation and bottom sheets for iOS using UIKit (56eba5bd2)
  • Add native bottom tab bar with dynamic tab support (68075a8bd)
  • Introduce graphs tab for easier graph management (60689b25f)
  • Add native editor commands toolbar on iOS (be09bf3c8)
  • Implement native alert dialogs on mobile (9c01d46bc)
  • Add native selection bar with improved UX (ec32fe359)
  • Support multiple navigation stacks for improved tab navigation (42aa764a6)
CLI & Developer Tools
  • Add validate command for local graph data quality checks (79e75060d)
  • Add validate option to export-edn command for sanity checking (07a0feb85)
  • Add API mode for export-edn command (62deed7e7)
  • Add validation to export EDN for most export types with explicit error handling (134dc0f2a)
UI/UX Improvements
  • Add unified icon picker with avatar support (6a0229eac)
  • Implement carousel component for improved onboarding flow (e08341bba)
  • Add Enter key functionality for onboarding navigation (2a4c0ef62)
  • Support global mode for custom font family (98b474e0e)
  • Add allow list feature for enhanced security (d737a447c)
Enhancement
  • Improve incremental transaction updates with 2,000 batch limit to reduce server load (f17d562ca)
  • Split RTC timeout configuration into WebSocket and S3 components (10s each) (002161132)
  • Make E2EE compatible with unencrypted graphs (bdf5d66f8)
  • Enable sync graph by default for RTC testers (df1e9d8bc)
  • Separate shared graphs from remote graphs in UI (e93c3afcc)
  • Auto-restart RTC when WebSocket timeouts occur (cc48b42d0)
Mobile Experience
  • Add undo/redo functionality on mobile (d1abefab0)
  • Add indent/outdent to selection bar with scrollable design (da26cbebe)
  • Support iOS Dynamic Type for better accessibility (7e8ed5333)
  • Enable swipe anywhere to go back (0a5ebf97d)
  • Allow search and view type switching on mobile (9d579a372)
  • Rename “favorites” to “quick access” for clarity (62f384e27)
  • Limit home journal page blocks to 50 for better performance (a5badf9e4)
  • Move import functionality to graph tab actions (a7c5baa09)
UI/UX Improvements
  • Redesign shortcut component with improved styling (c51e58a7f)
  • Refactor CMD K section header for better visual consistency (bcc68452f)
  • Enhance combobox with unified item rendering and improved styling (2ceb5e8ff)
  • Integrate list-item-icon component for consistent icon rendering (113d7cf99)
  • Add smooth scroll experience in select dropdown (3258aea29)
  • Add descriptions for DB export options to clarify their purpose (f6ce9fb47)
  • Improve error messages for unspecified graphs in CLI (7b07116b4)
  • Add option to relax closed validation for entity maps (36c361af8)
  • Improve validation error messages for better user experience (79e75060d)
  • Print unexpected errors in export-edn command (5489e7572)
Asset Management
  • Add file selection dialog for asset source input (9c738f64c)
  • Support external asset URLs with checksum validation (eeb8b8523)
  • Add external source editing for asset blocks (5e1c3a12e)
  • Improve external URL property visibility and styling (741e7db1f)
  • Add db-based highlights loading functionality (62edcebb6)
PDF Annotations
  • Improve asset path resolution and decoding logic (3874e39d1)
  • Improve highlight handling based on PDF state (97fb9811f)
  • Improve asset handling and highlight area interactions (ff3600ce5)
Bug Fix
Mobile
  • Fix capture view blink and keyboard issues (07ef1ec3b)
  • Fix re-tap capture resulting in blank app (1b8c5ac3a)
  • Fix keyboard blink when deleting a block (f6371eb37)
  • Fix editor toolbar not always displayed (a02c9d314)
  • Fix safe area handling (892c6c32e)
  • Fix navigation stack reset when switching tabs or searching (bf95e92ab)
  • Fix search requiring double taps (000280080)
  • Fix properties not shown on page view (eb2429dbc)
  • Fix delete block not focusing on previous block (de4c4bdcb)
  • Fix YouTube embed on mobile (b1e70e605)
  • Fix page title editing issues (682d3f641)
  • Fix menu popup positioning (92eb5acf4)
  • Fix node reference when text selected (606a95d6a)
  • Enable auto-correct and auto-capitalization on iOS (28c397e89)
  • Fix RTC not auto-restarting when WebSocket timeouts (53ae28359)
  • Fix assets sync loop stopping and error handling (285eb612a)
  • Fix RTC auto-restart error handling (c7816057f)
  • Fix create-get-state-flow not emitting nil (5b52b68ae)
  • Fix E2EE password requirement for non-encrypted graphs (9ca44ef15)
  • Fix E2EE reset password when local cached password expired (28a0ceb00)
  • Fix grant-access for E2EE graphs (de2c005b7)
Block Editing & Content
  • Fix inline tag resolved as page when saving block (20aecdb27)
  • Fix linked refs not shown for tags and properties (ae5d97ac0)
  • Fix parse inline tag as page (055a5cf6c)
  • Fix default-open-blocks-level 0 behavior (2b57fd9ee)
  • Fix fold button overlap with block title (c52476277)
  • Fix editor line-height (a8e2065ef)
Export & Import
  • Fix EDN export of class pages (22dbcfb2d)
  • Fix page export when blocks reference each other (ef68e19b3)
  • Fix import of existing pages to preserve properties and tags (3219b827e)
  • Fix invalid DB when class turned page has hanging :db/ident (fdc5d889d)
  • Fix file graph pasting blocks with multiple levels of children (9c77a2f2a)
CLI
  • Fix CLI append (-a) not appending (0f7135210)
  • Fix import-edn hanging for unexpected transact errors (4f5f68d0a)
  • Fix most API commands not pinging API when $LOGSEQ_API_SERVER_TOKEN set (b699ebf24)
  • Fix MCP server API mode failing confusingly (23937b59f)
  • Ensure CLI commands run against DB graphs only (d6a20e6a9)
  • Fix validate to ignore :block.temp/* attributes (deaed7d30)
PDF & Assets
  • Fix incorrect text layer rendering event handling for loaded pages (c8896fa8a)
  • Fix incorrect highlights layer for first page (54fdc5efd)
  • Fix assets not syncing to desktop (ddc8a566d)
  • Fix asset file deletion when deleting its block (d867bf603)
UI/UX
Property System
  • Fix property cardinality handling for property types (8c3e4f25c)
  • Relax closed values validation for server merge compatibility (8bd6acfb2)
Graph Parser
Performance
  • Optimize incremental transaction updates with batching strategy (f17d562ca)
  • Improve timeout configuration for better responsiveness (002161132)
Mobile
  • Limit home journal blocks to 50 for better performance (a5badf9e4)
Refactoring
Code Organization
  • Refactor icon handling and rendering logic for improved consistency (b45f7d541)
  • Refactor highlight rendering in search and cmdk components (4e269f644)
  • Refactor list-item-icon styles for better adaptability (44051947e)
  • Update importer to use validate-local-db (8fc56bfaa)
  • Make CLI and testing validation consistent (c8f99d1ff)
  • Rename local-asset? to local-relative-asset? (49407d561)
E2EE Cleanup
  • Remove deprecated E2EE namespaces and schemas (befac7f7a, 2c272cdef)
  • Remove unused deprecated E2EE code (d472efc03)
  • Extract delete-block-when-zero-pos for later usage (9af63ff9c)
Chore
Dependencies
  • Update DOMPurify from 2.5.4 to 3.2.4 for security (458d6d71e)
  • Bump CLI to version 0.4.1 (6b5e25bcf)
CI/CD
  • Use macOS-14 for desktop release CI (1ee40210f)
  • Remove outdated build-ios workflow (ce6b4ff2d)
Testing
  • Add E2E test for long block titles (21cf99c1a)
  • Fix RTC basic test for E2EE case (ef7901615)
  • Add frontend.common.crypt-test (e95dbe109)
  • Add flag to skip intermittently failing E2E tests (17cc2603a)
Documentation
  • Add dev instructions to build+install CLI locally (5153b0ba8)
  • Update review.md about common keywords (fb9ac9677)
  • Update roadmap link (547e86ab4)
Code Cleanup
Contributors
@benjypng, @charlie, @Gabriel Horner, @rcmerci, @Sal Rahman, @sander boer, @scheinriese, @Tienson Qin, @Victor239
Logseq Changelog: December 6, 2025 - January 11, 2026
Page Publishing Platform
A complete page publishing system enabling users to share their Logseq pages publicly via Cloudflare Workers. Features include password-protected pages, custom domains, URL shortening, dark theme support, search functionality, asset management, and customizable styling through logseq/publish.css and logseq/publish.js files (e5964202d)
Android Native UX
Major overhaul of the Android experience with native-feeling user interface elements including improved keyboard handling, better navigation patterns with multi-stack support, enhanced search views, and refined modal interactions (f910fcfea)
Database Auto Backup on Desktop
Hourly automatic backups for database graphs on desktop with clear UI indicators. Git backup has been disabled for database graphs to reduce confusion, though users can still use external Git for version control (cf80caebf)
New Feature
Publishing
  • Add complete page publishing infrastructure with Cloudflare Workers backend (36408416c)
  • Add password-protected page support using salted PBKDF2 hash (e77690b45, 8de2542f8)
  • Add custom domain support for published pages (8d6282121)
  • Add URL shortening with /p/short-id format (80388f618, 12f967437)
  • Add unpublish functionality (da314220d)
  • Add custom styling support via logseq/publish.css and logseq/publish.js (0ca329d63)
  • Add search functionality for published pages (c97453d1d)
  • Add user profile pages (be69c009d)
  • Add dark theme support for published pages (6d551e7b6)
  • Add 404 page for missing content (26c903f53)
  • Support math, code, and quote blocks in published pages (aab7cfe2d)
  • Support node embeds in published pages (62eb31c32)
  • Add linked references to published pages (e9c2269e3)
  • Preserve block collapsed state when publishing (76ebafac6)
  • Add keyboard shortcut mod+m to publish pages (15585f148)
  • Update published-url property to type :url (d53ea4a38)
Properties & Tags
  • Add tag-scoped property choices allowing properties to have different choice sets for different tags (a9a9905b0, 6ba05ad2c)
  • Add ability to hide global choices per tag (a9a9905b0)
  • Add createTag API support for tag properties via :tagProperties parameter (baff8a4cc, 8fd006bab)
  • Add tag-related APIs for enhanced tag management (e5903e1c2)
  • Add data attributes for property title and type (5f42c51c3)
  • Add reset option to upsertBlockProperty for block properties (460eefb96)
Mobile
  • Add Android native UX with improved navigation, search, and keyboard handling (f910fcfea)
  • Add multi-stack navigation system for mobile (cbb755617, 4b1d51ae4)
  • Add native search view for mobile (803a37363)
  • Add create new graph link to graph switcher (1caefaef6)
  • Add bottom sheet for login instead of dialog (71866e50e)
Developer Tools
  • Add debug logging tool for RTC with transaction and WebSocket message tracking (27016657f)
  • Add setFileContent API to update built-in files like custom.js/custom.css (8d7aaa791, 6c1b9fe77)
  • Add route handler and improve page block retrieval APIs (8cfcefcec)
Flashcards
  • Add automatic query property block creation when tagging with #Query or subclasses (41cbba368)
  • Add plus button to create new #Cards blocks directly from flashcard modal (41cbba368)
Import/Export
  • Add Zotero import support for external PDF files (33db791ac, 270f13f11)
  • Add support for importing block tags specified via tags property (045cd5f53)
Enhancement
Performance
  • Optimize linked references query performance with and without filters (60f6c7613, 8541b7c79)
  • Separate scalar from ref property queries for better performance (aea9f09fd)
  • Separate default value queries from others (aea9f09fd)
  • Import properties first and then other datoms for faster imports (aea9f09fd)
Query System
  • Extend tags query to return blocks with children tags and support eid/title/db-ident formats (1ae9e2c49)
  • Add highlight support to unlinked references (1cf4fa9ef)
User Experience
  • Prompt user to input encryption password when creating first sync graph (be26d4278)
  • Show clear indicator that hourly backup is running on desktop (6f513fa51)
  • Run database validation before graph EDN export (e5982b678)
  • Improve select match behavior (c167b6954)
  • Don’t close invite dialog after submission (9bd5390c0)
Mobile UX
  • Show page above block in search results (ddcfe0209)
  • Save recorded audio to quick add when capturing (edb9f914c)
  • Polish UI spacing and background styling in various components (c75322f55)
  • Improve modal handling on back navigation (1413ab97d)
Security
  • Update encryption iterations for encrypt/decrypt functions with versioning (bef3939f3, 85211e95d)
  • Set authentication to required on staging and production publishing environments (918dc0766)
  • Limit password KDF iterations on Cloudflare Workers (3b1433647)
PDF & Assets
  • Add extern hints for pdfjs APIs (b10753502)
  • Improve layout for block title wrap in PDF styling (c9f1920e1)
  • Improve external asset workflow wording (e0f136a36)
  • Add support for multiple image size variants in publishing (a3d717812)
Plugin System
  • Add note for setBlockIcon method in plugin APIs (dc4c71208)
  • Improve property label rendering with plugin identification (74fa40103)
  • Add plugin documentation sync GitHub Actions workflow (e8d06f6fa)
  • Simplify tag resolution and enhance tag handling functions (44468dd20)
  • Add ability to sort plugins by added date on marketplace (ebb985f78)
CLI
  • Add -h/--help flags to CLI commands (ee97b8cda)
  • Bump CLI version to 0.4.2 (87dff14f4)
  • Add dev CLI task for easier testing (fe55fdf81)
RTC
  • Add :add operation to replace :move + :update combo for efficiency (4dc4e1be7)
  • Add more context when apply-ops returns :not-found-target-ops (75a131238)
Documentation
  • Update libs links to be compatible with DB (a630835ce)
  • Add development notes for libs (d1bbb5ad1)
  • Update db_properties_skill.md with enhanced property schema APIs (2642765eb)
Bug Fix
Page Publishing
  • Fix tagged nodes rendering in published pages (adb7b8e36)
  • Fix AST blocks in block titles (15d7526ac)
  • Fix heading rendering (2068123b2)
  • Fix page icon display (78fbbaffa)
  • Fix positioned properties rendering (5ed49d737)
  • Fix icon and tags positioning (b1050da84)
  • Fix URL type property now rendered as clickable link (ef7cbd743)
  • Fix property rendering issues (08ab09a44)
  • Fix mobile display issues in publishing (efaff72f0)
  • Fix asset upload in publishing (b182a3736)
  • Fix caching for published pages (0c79f4651)
  • Don’t show published URL property in main UI (6bc2fb1a0)
  • Remove icon from page properties area in publishing (bdb6e0218)
Mobile
  • Fix keyboard toolbar position on Android (56593a092)
  • Fix search crashes on Android (b7cd27a92)
  • Fix editor toolbar moving webview to top (ffa695626)
  • Fix navigation history pop behavior (636bf9283)
  • Fix slow rendering after searching and returning to home (f1f8f22de)
  • Fix widget shortcuts (489f7afed)
  • Fix foldable control (60b8e9298)
  • Fix cold start capture first doesn’t render other journals (f7207d2d2)
  • Fix favorite icon doesn’t update status (efc9f36b6)
  • Fix home button in root tab doesn’t scroll to top (b9928a150)
  • Fix clicking icon and properties redirecting to page (9cfb7f0b2)
  • Fix swipe on node link now correctly opens the node (135878a78)
  • Fix duplicate assets created when sharing to mobile (2801130bb)
  • Fix main content horizontal scrolling disabled (07cc46663)
  • Don’t set background color when hovering favorite item (34858d43e)
  • Fix number property cannot be edited if value is empty (6dacc20fa)
  • Fix capture can’t open block to edit (3c79dff81)
iOS Specific
Properties & Tags
  • Fix tag-scoped properties showing for other tags (79f5c6e3c, c2582d3c2)
  • Fix property value in table view doesn’t render for new objects (77c3ddf49)
  • Fix new option now appears as first choice in dropdowns (8ee2bc0ee)
  • Fix number 9 can now be set as property value (8fc093c1c)
  • Fix :block/warning value now correctly uses keyword type (aafa50dcc)
  • Don’t hide right positioned properties (7b063be30)
  • Allow properties to use rename-db-idents (390bf94ca)
  • Ensure using :rename-db-idents to rename properties in migrations (016e63c4a)
Block Editing
  • Fix copy and pasting blocks with dates now works correctly (82a1932e9)
  • Fix page reference now recognizes pasted text (e29cb6d5a)
  • Fix collapse/expand toggle on mobile (51634b4c5)
  • Fix delete page no longer results in invalid data when children blocks reference parent page (bc6ab3867)
  • Fix pressing delete no longer closes right sidebar (cf80caebf)
  • Fix asset ordering issues (10846fdaa)
Import/Export
  • Fix pages starting with “@” now import correctly from Markdown (b2497c0cc)
  • Fix pages now have #Page tag when importing from Markdown files (81cbc1e70)
  • Fix external PDF file support when importing from file graphs (270f13f11)
  • Fix Zotero import for PDF blocks (33db791ac)
  • Fix PDF annotations regression in file graphs (98fad292e)
  • Fix export of property values for :many properties with additional attributes (529be0496, 86023329c)
  • Fix export of property value blocks to keep their UUID when referenced (b696a84ca, 1effbdfad)
  • Fix duplication of exporter config (b4f3e364e)
  • Fix refs not built for imported EDN from UI or CLI in-app graph (dce3b4111)
Search & Navigation
  • Fix search highlights now works for pages (fd52fb50c)
  • Fix pages backlink count no longer resets to zero (6020df880)
  • Fix recursive alias redirect handling (260f6511f)
  • Fix navigation stack behavior (4c1b0b5d3)
  • Fix reset search stack (57fcd5996)
RTC & Sync
  • Fix RTC batch store and validate database operations (f594e2034)
  • Fix logseq.db/transact! no longer distincts tx-data to prevent invalid state (f594e2034)
  • Fix lost first block’s RTC ops when pasting multiple blocks (208e3df66, bcad78227)
  • Fix RTC never retracts block timestamp (f940f708b, 4b7d6c73c)
  • Fix invalid apply-ops message (f1a410887)
  • Fix update-page operations that don’t need update-block-attrs (69f0df24f)
  • Fix update-page local-op to remote-op conversion (efdebeaac)
  • Fix carefully compare timestamps when adding ops to client-ops (ff7ecc4ba)
  • Fix clean cached local-t and remote-t while downloading graph (b947f8760)
  • Fix :logseq.property.asset/remote-metadata shouldn’t be ignored during init-download (cec20a543)
  • Fix custom-decode for :block/name (707ef76ad)
  • Fix E2EE password confirm inconsistency (f927ae8b7)
Database Operations
  • Fix property value blocks with UUID now generate UUIDs and tags correctly (a5875420d)
  • Fix validation errors that failed to pretty print with stack overflow (1fe486542)
  • Fix shouldn’t retract db/ident when validating and fixing database (f77a4ba96)
  • Fix invalid data issues (0b406c487)
  • Filter out file graphs in database operations (50e2bc53f)
  • Fix d/entity print output (954b3b41f)
  • Ensure :block/title and :block/name are correct for built-in pages (eda73175f)
Flashcards
  • Fix critical bug where end? parameter had inverted conditional logic in api-insert-new-block! (41cbba368)
  • Add back missing dictionary entries for flashcard buttons (60e79785f)
Media & Embeds
  • Fix YouTube timestamp playback on web and Electron (4d46c5e9b)
  • Fix YouTube embed on desktop (e95c93629)
  • Fix external audio not rendered by renaming external-src-to-external-url (57a012bcc)
  • Fix PDF highlights can now be copied (a97fec165)
APIs
  • Fix logseq.Editor.renamePage HTTP API no longer hangs indefinitely (664743b28)
  • Fix plugins setup for mobile web platform (7aea01d77)
CLI
  • Fix CLI can now run in CI environments (a4d3bd4d9)
  • Fix import-edn and mcp-server commands don’t transact refs for local graphs (9d49ba6d4)
  • Add JS dev dependency to db for CLI command development (068dbf266)
UI & Styling
  • Fix datepicker now includes missing CSS file (7d493575d)
  • Fix UI JS path (dcf754329)
  • Fix padding for property configuration header (5ff22217d)
  • Fix vertical line collapse behavior (33e34ab1b)
  • Fix MCP server toggle now only shows on Electron (401fce3a7)
  • Add warning on Excalidraw (bab068ac3)
Built-in Pages
  • Fix “Quick add” page can no longer be made invalid (2b80c5a04)
  • Ensure local graphs have UUID (c21f2c7f4)
  • Add :logseq.kv/local-graph-uuid (b55550ed3)
  • Mark ensure-graph-uuid as deprecated (6f59a02f5)
Miscellaneous
  • Trim whitespace for inviting email addresses (0b77ee902)
  • Fix wrong mobile event handling (f43459f55)
  • Fix auto backup issues (afd421090)
  • Fix capture error now supports extra data (05f21dd8b)
Refactoring
Architecture
  • Separate original and database version apps, removing file sync, Tldraw, Excalidraw, and Zotero from database-only version (bcc478b5f)
  • Remove file-based model completely (d8d6e8b4b)
  • Remove file-based handlers, commands, and API (9f927137a, bbe6fa861, eaa5a5733)
  • Remove Git, Chokidar, and rsapi dependencies (f1de1ea16)
Code Organization
  • Separate worker into multiple namespaces for publishing (12fabc63c)
  • Prefer conn over repo parameter for outliner core and RTC updates (7d719623a)
  • Add transact-with-temp-conn! function (f594e2034)
Chore
Dependency Management
  • Bump nbb-logseq and add tests for ldb/transact* functions (f594e2034)
  • Upgrade libs core and yarn.lock (5f185a39c)
  • Bump libs version to 0.2.9 through 0.2.11 (61d28c307, a2bfb3963)
Cleanup
Translation
  • Update Italian translation (020f65b00)
  • Fix typos in Polish translation (8da7e7604)
  • Update Portuguese (Brazil) translation (f88b0c63d)
  • Rename Encryption tab to match description (8c2733111)
Testing
  • Add asset-blocks-validate-after-init-downloaded test (8d7ce3989)
  • Add paste-multiple-blocks test for RTC (5918429db)
  • Add RTC extra part2 tests (73ee1bbc1)
  • Add E2E test for isolated scope properties (6ba05ad2c)
  • Add tests for tag-scoped property choices (a9a9905b0)
Contributors
@A.S., @Charlie, @Gabriel-Horner, @Laer-tty, @Mega-Yu, @Paweł-Świątkowski, @Piotr-Narel, @Tienson-Qin, @albanobattistella, @rcmerci, @scheinriese
Changelog (2026-01-13 to 2026-03-23)
Spotlight
This release delivers three major initiatives that dramatically reshape Logseq’s architecture and user experience:
  • New Sync Architecture (Worker Sync) with Self-Hosted Option — Complete rewrite of the real-time collaboration and sync engine, moving to a worker-based architecture with Cloudflare D1 metadata, R2 storage for snapshots and large block titles, end-to-end encryption (E2EE), sync checksums, chunked graph import/export for large graphs, collaborative presence indicators, and robust offline conflict resolution with rebase semantics. This replaces the legacy RTC implementation and brings significantly improved reliability and performance.
  • Keyboard Shortcut Redesign — Ground-up redesign of the keymap settings UI with a new three-mode shortcut badge component (inline, glow, compact), full keyboard accessibility (arrow navigation, ARIA roles, focus management), two-tier conflict detection (exact vs prefix), inline undo feedback, theme-aware keycap animations, shimmer sweep highlights, and intelligent cross-handler conflict resolution. The settings page now suppresses action execution while browsing shortcuts.
  • Logseq CLI — New command-line interface for programmatic graph interaction, offering offline search, Datascript queries, block/page/tag CRUD operations, graph import/export, doctor diagnostics, sync integration, shell completions (bash/zsh), and a db-worker-node backend. Developers and power users can now manage Logseq graphs entirely from the terminal.
New Feature
Real-Time Collaboration & Sync
  • Implement worker-based sync architecture with Cloudflare D1 metadata and R2 storage (75ff633380)
  • Add end-to-end encryption (E2EE) for graphs with per-entity leaf node encrypt/decrypt (1f71f9e78e)
  • Add sync checksum for data integrity verification (917309113f)
  • Add sync rebase with offline conflict resolution (576bcc5132)
  • Implement recycle (soft-delete) semantics for synced blocks (174cdfd865)
  • Add collaborative editing user avatar presence indicators (36c5afeece, d181b1bfa9)
  • Add emoji reactions to blocks (05be455371)
  • Add graph member management — invite collaborators, remove access, and leave graphs (59e1cd9af9, 35d28a976e)
  • Support zip-based graph import and export with progress bar (199ecb6bbd, 267587a551)
Keyboard Shortcuts
  • Redesign keyboard shortcut component with 3 display modes: inline, glow, and compact (67c123b4ed)
  • Implement V3 shortcut customization popover with two-tier conflict detection (def3dfb233)
  • Add tiered prefix-conflict banners and cross-handler detection (1cd7cad8ae)
  • Add inline compact keycaps in prefix-conflict banners (22a165472a)
Bi-directional Properties
  • Add bi-directional property support with class-scoped relationships (3f8c6cde92)
  • Add async query support for bi-directional properties (164d1c908c)
Search (Cmd+K)
  • Add code search functionality (cacf846bd2)
  • Implement Cmd+K state persistence and search options (aa74295d44)
  • Add current page badge with context-aware filtering (6b1f4f4ac4)
  • Add snippet highlighting with windowing for multi-term queries (3f8be4f3ed, 968a730724)
  • Implement scroll helpers for focus visibility and wheel anchoring (4cd5bfc102)
Import/Export
  • Add template import support in exporter (371b1d5301)
  • Add support for Template, Math blocks and Cards in exporter (ecad45531d)
  • Add code snippet extraction functionality in exporter with UI options (1c351aebff)
  • Support Zotero linked file import (zotfile-style) (1162f33c77)
Plugin System
  • Add support for invoking external plugin commands (55216f36f0)
  • Add support for DB graphs in plugin UI (6be47c18be)
  • Add managing property choice values API (e94959690d)
  • Add setPropertyNodeTags API for managing property tags (af51223ff6)
  • Add today page API (110084e4ba)
  • Add comprehensive initial Arabic translation (3d5758e9b0)
Enhancement
Sync & Collaboration
  • Stream snapshot import in batches for large graphs (f6b5a100d6)
  • Parallel asset uploading for faster graph sync (e18751c54e)
  • On-demand asset download instead of bulk download (53ca427ac7)
  • Gzip graph download for reduced transfer sizes (8bbc0fede8)
  • Upload large block titles to R2 storage (e7bb0963d4)
  • Cache user keys to speed up first sync (6bf5ae4682)
  • Use cache token for faster connection handshake (7bb9b50764)
  • Improve sync startup latency and connection flow (560ce3ca4f)
  • Improve snapshot import progress UX (80b48b7b86)
  • Preserve rebased tx boundaries for RTC (e3366e8e07)
  • Trigger sync after creating new remote graph (d46b66c228)
  • Fetch graphs automatically after login (1aa16b5355)
Keyboard Shortcuts
  • Arrow key navigation and focus management in keymap settings list (e45fb29061, 3aa5a36d4a)
  • Replace menu shortcut hints with shui components with glow style (ffbcd4fc90)
  • Suppress shortcut actions on keymap settings page (animate-only mode) (3359396c3d)
  • Theme-aware glow and brightness keycap animations (00e2a91f25)
  • Accent shimmer sweep row highlight on shortcut trigger (4dcdbcc44c)
  • Responsive keymap tab with ResizeObserver-based width sync (06d890f6ca)
  • Gradient fade header when search removes section headers (bf7ebc8d7e)
  • Redesign keymap header with search-first layout and contextual status (1594a122cc)
  • Replace external toasts with inline undo feedback in shortcut popover (776f5abc0a)
  • Internationalize all hardcoded English strings in shortcut redesign (c3df1d857d)
  • Add ARIA live regions, role=dialog, and aria-pressed for accessibility (ed0d6f0142)
  • Suppress animations for prefers-reduced-motion (6502bb53f6)
Search (Cmd+K)
  • Enhance mouse hover effects and highlight styles in search results (f49e472402)
  • Improve keyboard and mouse highlight handling (4514e0e989)
  • Enhance lazy visibility handling with root parameter for scroll management (8408cf55f3)
  • Optimize item rendering frequency and scrolling behavior (72c97dae21)
  • Improve input handling and reset scroll position on input change (73b6b7e0a4)
Export/Import
  • Export-EDN now exports property history (b18056c910)
  • Export-EDN exports nested children of text-property values (8216e1a177)
  • Export-EDN supports :build/properties in property values (5e43f89af2)
  • Export-EDN handles assets (991e38419a)
  • Ensure export EDN is idempotent across import and export (f28e001b5a)
UI/UX
  • Improve headings function to include normal text option (767540d85b)
  • Align for the image asset block container (1b0db68098)
  • Polish settings item alignments (ffdc77c5c4)
  • Add loading state and skeleton UI for user list (fa9a07b8df)
  • Add styles for priority level icons in property component (f6996c5e3e)
  • Block collapse state isolated per container (a0f737e3a8)
  • Copy as/export add open blocks only (a092470392)
  • Published page shows tags prefixed (7554e4e3f9)
  • Improve property sorting and display with plugin name (f818ba0e59)
  • Adjust image width in property value class (13e9781a1c)
Developer Tools
  • Add linters for db-sync module (cd7c1ef50e)
  • Add workflow to run db-sync tests (c1ca626b36)
  • Add linters and workflow for publish module (cd8f312b9f)
  • Able to generate large graphs with >1M blocks for testing (b1ceaa1216)
  • Add Sentry error collection (ef17ce59c3)
  • Add publish documentation (5d4a91eb7e)
Bug Fix
  • Handle recreated lookup refs in sync (2801276ce1)
  • Disable checksum for encrypted graphs (6ca2cc4312)
  • DB-worker stops working after hot-reload (55834b541d)
  • Improve undo/redo merge reliability for sync (7c5146afcd)
  • Cut-paste losing children after sync (7cddf537da)
  • Undo should skip conflicted move instead of clearing stack (c1a9bee798)
  • Batch tx should separate schema ops from data ops (e7bcdb0bcc)
  • Fix malformed remote tx including temp entity IDs (8d48e93ccb)
  • Fix missing :block/title during sync (ae9a37c889)
  • Reject stale pull response (7e565aeeeb)
  • Auto-reconnect after long sleep with websocket health check (dbef84fbb4)
  • Refresh access token when expired (dcb26353ec)
  • Undo/redo shouldn’t write invalid data to server (667e0d7f05)
  • Fix large graph download OOM (1b4ad6a416)
  • Fix attrs missing when rebase (fb57514530)
  • Offline conflicts with deleted nodes, parent cycle, and extends cycle (2f1b70b865, 0cf01ba780, ebf768e340)
  • Isolate chunked import sessions and close failed import setup DBs (6c3a94ea04, 0007c48003)
  • Reduce memory usage when encrypting large graphs (98e262d118)
  • Isolate E2EE import temp pool and reduce finalize memory (880d7d2c3f, 1b4943350b)
  • Server shouldn’t delete addrs; drop stale lookup-ref tx datoms (7386eec6db, 5d602c9d58)
  • Fix collaborator invite not working with E2EE (9e7f9332d0)
Keyboard Shortcuts
  • Limit prefix-conflict detection to same-handler only (e8bddda236)
  • Handle prefix conflicts and disabled edits (b3c9f75eec)
  • Fix conflict detection between block-editing and editor-global handlers (01f9904062)
  • Fix Option key recording and show ⌥ symbol on macOS (19c878cba0)
  • Fix chord-prefix shortcuts not being stripped during reassign (e8542d3028)
  • Fix focus loss in customize popover after Reassign and state transitions (8088b6f3f8)
  • Fix plain key recording, conflict detection precision, and quote formatting (82d699fc22)
  • Normalize undo bindings to prevent false Custom classification (814acd49fd)
  • Decompose customize dialog, fix reset conflict race, and auto-close popup (33dcefaa06)
Import/Export
  • Fix import of multi-word tags (3d88cd1fd6)
  • Fix import of namespace tags (e7bfd53a7c)
  • Fix import of unlinked PDF annotations (23d6f1538a)
  • Fix importing journals with tags (98ab051328)
  • Fix importing property values that change (4cc8ef3ce4)
  • Fix imported Template blocks property handling (fdf1a8f8cc, ae003f1469)
  • Fix Zotero import issues — linked files, picture highlights, and label/filename inconsistency (40c9c86129)
  • Fix UI import of example graph becoming invalid (6acf799b68)
  • Fix CLI import results in invalid nodes (e7b5c9a6b6)
  • Fix export tests with large graph having duplicate built-in pages (16beb18c92)
Search
  • Make FTS index build non-blocking (d8e7032e78)
  • Fix overlapping term matching for highlighted snippets (ad2a067ab7)
  • Fix unnecessary highlighted snippets in [[]] block search results (6263ba06d9)
  • Ensure case-insensitive comparison for page name matching (77305aaf19)
UI/UX
  • Fix Cmd+K hint showing Mac icon on Windows (2729eb58bd)
  • Fix ‘Copy ref’ rendering (()) instead of [[]] (3ae0ab9f5d)
  • Fix left sidebar resizer activating when sidebar is closed (5fe47fb69f)
  • Fix right sidebar toggle functionality (e6b5b1e372)
  • Fix blocks selection bar can’t be opened after visiting Graph view (5658b32153)
  • Fix incorrect sticky position for table header (e203d0465c)
  • Fix dropdown menu for choices values display (f023071ac3)
  • Fix UI refresh loop with custom journal format (a0b109399d)
  • Fix today journal created-at/updated-at keep updating (ed240ac01e)
  • Fix collapse button alignment on mobile (ea42e7595b)
  • Fix bullet disappearing when dragging (9c0bb07b82)
  • Fix drag-and-drop creating a blank asset (afe21733a2)
  • Fix CSS overflow for flex items (3c9c18500f)
  • Fix new window behavior (2cabb09248)
  • Fix re-ordered tx data by replace-attr-retract-with-retract-entity (eaa0d6ff96)
  • Fix invalid data when deleting closed value (3c9dee98da)
  • Fix react query not computed after importing data (d4d408f47e)
  • Fix can’t paste block with children to empty target (8116067f85)
  • Fix can’t cut-paste blocks to empty target (b0ba993e0c)
  • Fix journal title shouldn’t be updated (regression) (4bf39b576b)
  • Cleanup processes all retracted entities including pages (e6e61e235a)
  • Fix get-bidirectional-properties performance (cdc1bc1d32)
Plugin System
  • Fix updateBlock plugin API not updating UI (546499ef04)
  • Fix return value in hook-lifecycle-fn! (3a3e14b790)
  • Fix published :url :many property values (22912bdd7e)
  • Fix case page retrieval with safe navigation (911caa0673)
PDF & Assets
  • Set correct MIME type for Blob based on file extension (9994f7b70d)
  • Include last visit page in highlights response (cfbceea453)
  • Update PDF drag-and-drop data format to use double brackets (4f54340115)
Mobile
  • Fix mobile sync indicator latency (a1cbcf8aaa)
  • Notify when no microphone permission (99fb07586e)
  • Show camera warning when no permission (108098dd4d)
  • Simplify user login handling for native platforms (ffb82f1ccc)
Performance
  • Reduce memory usage during large graph encryption (98e262d118)
  • Make search index build non-blocking (d8e7032e78)
  • Optimize sync startup latency with cache tokens and key caching (560ce3ca4f, 6bf5ae4682)
  • Optimize get-bidirectional-properties (cdc1bc1d32)
  • Stream snapshot imports in batches (f6b5a100d6)
  • Efficient undo/redo validation (a02d157cab)
  • Optimize item rendering frequency in Cmd+K (72c97dae21)
Refactoring
Architecture
  • Remove file-based graph code, whiteboards, tldraw, and org-mode from the codebase (0e2a223b2b) — comprehensive cleanup of legacy file graph references across frontend, electron, graph-parser, and deps
  • Separate sync into modules (16f775c9ad)
  • Simplify remote sync flow (071677859d)
  • Batch outliner ops via temp conn (68476aee3e)
  • Keep worker as thin as possible; use reitit for worker routes (f46c245788, cd0a2568b1)
  • Remove legacy RTC implementation and tests (8472d03826)
  • Remove repeat definitions of ls-api-call! (e5c378f6d9)
  • Graph download switched to use R2 snapshot (eeabd54d87)
  • Use Cloudflare D1 instead of DO for graph metadata (f0efeb31bc)
Code Quality
  • Defer prefix-conflict banner to post-reassign state (a3471e0406)
  • Deduplicate binding resolution in ui.cljs (befe49275c)
  • Use cond-> for container-attrs in shortcut badge components (8d62b4d6bc)
  • Simplify db sync for recycle semantics (fb76b061b4)
  • Convert remaining frontend tests to db graphs (6c876a0be2, e07ff6dd88)
Chore
Upcoming (Unmerged Branches)
Logseq CLI (feat/cliable)
  • Full command-line interface with verb-based subcommands: add, show, list, move, upsert, query, export, import, doctor, sync, completion (7b2ef7fce2)
  • Datascript query execution from the terminal (6f3d074195)
  • Shell completion generation for bash and zsh (051f6381e3, c4d52878bc)
  • Block upsert with custom many-property JSON support (791b3e98f7)
  • Tag and property management commands (85ebeb976e)
  • Doctor command for graph validation (4c10100aa6)
  • Sync download with real-time progress (a89ffb6b0f)
  • Graph list showing current graph, sorting, and field selection (0900b9b41b, fbfb589c52)
  • Linked references display in show command (33b8a3207d)
  • Desktop app refactored to use db-worker-node backend (cafe755091)
  • CLI E2E test suite with shell-based integration coverage (2cc0735e3a)
Package Upgrade (refactor/package-upgrade)
  • Upgrade Capacitor to v8, Electron Forge, better-sqlite3 to v12, Sentry to v8, Playwright to 1.58 (862c9ec150, 9e57698565, 6a276cba0f)
  • Upgrade KaTeX, fuse.js, webpack, postcss ecosystem, and many more runtime/dev dependencies (397d46ac3b, 2aedbc06a5, 05f9f5ab36)
  • Remove dead dependencies: shepherd, tippy, react-draggable, storybook, posthog-js, meander, electron-builder (f156e739c7, cec005f02f, ba54f82beb)
  • Replace grapheme-splitter with native Intl.Segmenter (ad13d16ca4)
  • Replace electron-deeplink with native Electron API (d1b7f1d86f)
  • Upgrade DOMPurify and unify sanitizer path (afe42a4cb5)
  • Upgrade clj-kondo to 2026.01.19 across all deps (afc97fb165)
  • Update Tabler icon font assets (a67fad3276)
Libs Restructuring (refactor/libs)
  • Optimize message transport using MessageChannel for faster plugin communication (a9f1df22ae)
  • Add hosted renderer registration and resolution for right sidebar (370e1d55b2, e20efb0c9f)
  • Add get_current_route API (9990a58aee)
  • Streamline handshake process and improve error handling (677c8c2791)
  • Improve layout data handling and restore logic (0e81b38f6d)
  • Marketplace plugin installation E2E tests (03336eb192)
Icon Context Menu (enhance/set-icon-with-context-menu)
Custom Block Properties Renderer (enhance/custom-block-properties-renderer)
  • WIP: Add custom block properties renderer with matching conditions for plugin-driven property display (e033b1b5cc)
Image Alignments (feat/alignments-for-image)
  • Add alignment options (left/center/right) for image asset blocks with keyword-based property (d377b2d2f7, 536b1ca963)
  • Select block on double-click in image asset container (21a2a2e915)
Import Fixes (fix/import-issues)
  • Fix block attribute names containing “/” after importing (02e17ec69f)
  • Fix multiline blocks containing attributes being truncated and losing data after importing (25021eb15b)
Contributors
`@Ashutosh-Singh, @briansunter, @charlie, @Danzu, @Gabriel-Horner, @ibs-allaow, @jariji, @matugong, @Mega-Yu, @rcmerci, @Rustum-Zia, @scheinriese, @Tienson-Qin, @Tomasz-Kontusz`
Changelog (2026-03-23 to 2026-04-26)
Spotlight
This release focuses on making Logseq’s database graphs more reliable at scale, expanding the CLI into a much more capable graph-management tool, and improving everyday speed in large graphs.
  • Sync Reliability and Self-Hosted Flexibility - Add graph merge strategies, custom sync server URLs, worker-driven downloads, stronger encrypted sync bootstrapping, and a broad set of checksum and replay fixes that make sync more dependable across desktop, web, and CLI workflows.
  • CLI Expansion - Add task, node, asset, search, backup, debug, browser-open, and skill-management commands, then harden them with atomic updates, better completions, clearer output, and safer validation.
  • Large-Graph Performance and Polish - Speed up indexing and large-page rendering, improve view loading for heavy graphs, and ship a wide set of UI fixes across sidebars, settings, journals, assets, and page controls.
New Feature
Sync and storage
  • Add graph merge with three conflict-resolution strategies: last-write-wins, keep-target, and report-conflicts (44ef506db7).
  • Add support for custom sync server URLs so teams can point Logseq at self-hosted sync infrastructure (8997638e5b).
Developer tools
  • Add CLI task commands for creating, listing, and updating tasks directly from the terminal (9855011e62).
  • Add CLI commands for listing nodes, searching graphs, backing up graphs, pulling sync state for debugging, opening graphs in a browser, and managing skills (e41aee18b2, 59d0e5777b, 4cedd99255, 8e98d70ebb, fdf7eed219, 9bac1ae4dd).
  • Add CLI asset workflows so scripts can list and upsert assets without leaving the terminal (1ae912fd92).
File handling
  • Add block context menu actions to set an icon on a block and open an attached asset file directly from the desktop app (cdab06f984, eb1d921d5d).
Settings and configuration
  • Add a new yyyy-MM-dd EEE journal date format for users who want weekday-aware journal titles (da07a518d5).
Enhancement
Search and queries
  • Speed up search indexing, show indexing progress, and improve command search for multilingual graphs with bilingual and pinyin matching (7edeae6971, 7fa6a1d99c).
  • Improve page and query UX with better page-property view context handling and a clearer command palette hint flow (591bfa9d22, 066514f545).
Developer tools
Sync and storage
UI/UX improvements
Plugin system
  • Improve the plugin sidebar renderer and normalize plugin user keys so plugin integrations behave more consistently across DB graphs (08f197ded9).
Bug Fix
Sync and storage
Developer tools
Database operations
UI/UX improvements
File handling
  • Fix language and input issues so slash commands follow the selected locale, email fields validate properly, and date-format changes stop causing logic regressions (632ec2f362, 445f2e5ae8, 5a752ef99d).
Performance
Search and queries
  • Speed up index building and large-graph search workflows so results become available sooner and indexing progress is visible while work is in flight (7edeae6971, 7fa6a1d99c).
Database operations
  • Improve large-graph rendering and editing by optimizing recursive UUID title replacement, reducing expensive datom scans, and avoiding unnecessary temp batch transactions in common block operations (94ea551ec4, 73bc59857e, 28c8a00c94, 502103855b, 5147b0e20a).
UI/UX improvements
Refactoring
Sync and storage
Developer tools
  • Simplify the CLI surface by replacing --data-dir with --root-dir, centralizing output-mode handling, and splitting long-running test coverage more cleanly across local and sync-heavy suites (f751f27a63, 22f1e6c867, 5904433787).
Plugin system
  • Refactor plugin libraries to support the new sidebar integration path and newer DB-graph APIs (a95483655b).
Chore
Developer tools
Contributors
  • Charlie, eliovir, Gabriel Horner, hoellen, Danzu, Mega Yu, rcmerci, Ritvik Sharma, SHI SHUJUN, TechnoHouse (deephbz), Tienson Qin
  • Total analyzed: 566 non-merge commits
Changelog (2026-04-27 to 2026-05-16)
Spotlight
This release ships Logseq’s first round-trip between DB graphs and on-disk markdown, expands the CLI with native query support, rebuilds the graph view, and hardens sync across reconnects, encrypted graphs, and large payloads. The closing days added a polish pass on Graph View V2, a new :asset property type, and a handful of quality-of-life features.
  • Markdown Mirror — read-only on-disk markdown projection of DB graphs that updates as you edit, with per-graph opt-in, path-collision handling, and rename-aware cleanup (PR #12589, PR #12594, PR #12596, PR #12607). Two-way sync is in development on a feature branch.
  • Generated mirrored markdown
    • …/graphs/cliworker/mirror
      ❯ tree
      └── markdown
          ├── journals
          │   ├── 2026_05_02.md
          │   ├── 2026_05_07.md
          │   ├── 2026_05_14.md
          │   └── 2026_05_16.md
          └── pages
              ├── Logseq Markdown Syntax.md
              ├── Project.md
              ├── Test Project.md
              └── Testing Plugin.md
  • CLI matures — qmd query for multi-part queries, asset download for sync, a unified backup path shared with the desktop app, and a fully bundled CLI in desktop releases (PR #12340, PR #12548, 635d4b7a73, 08a479f2c8, 3f5b52cc07).
  • Graph View V2 — rebuilt for faster rendering on large graphs, with a follow-up task zoom-in view and interaction polish (PR #12604, d12beff383, 9318205c32).
  • Sync reliability — caps oversized snapshot payloads, scopes RSA key pair caches per server URL, recovers stale websocket sessions, and clears a long list of checksum, reconnect, and asset upload edge cases (PR #12586, 293309801f, 70042a46df, 009d93dc92).
  • Quality-of-life polish — $ autopair for inline math, AVIF/CR2 image support, “Always on Top” window option, marketplace plugin search across descriptions, plugin thumbnails, and a wide pass of editor, import, and graph view fixes (PR #12618, PR #11997, be34b7904a, PR #12470, 5726ecaa21).
  • :asset property type — first-class asset property with inline thumbnail picker, so file/image references live in a typed property slot (PR #12506).
Currently Available
Features, enhancements, and bug fixes merged to master .
New Feature
Sync and storage
  • Markdown Mirror writes DB graph blocks to disk as plain markdown, updates as you edit, embeds block ids in comments, and handles renames and path collisions (PR #12589, PR #12594, PR #12596, 4bde9e0111, 9288c1de7e).
  • Logseq-markdown export shares content in Logseq’s own dialect outside the app (PR #12598).
Developer tools
Plugin system
  • Custom block renderer hook lets plugins render their own block UI inside the editor (PR #12533).
File handling
  • “Open folder” action jumps to a graph’s files from the repository context menu (7306cc8916).
  • Configurable Publish server URL points self-hosted setups at their own publish backend (PR #12520).
  • prettify-url? option on QuickCapture auto-formats captured URLs on save (PR #12409).
Media
  • Native AVIF and CR2 image support renders RAW photos and AVIF assets inline (PR #11997).
Window management
  • “Always on Top” pins the Logseq window above other apps (be34b7904a).
Properties
  • New :asset property type opens a 4-column thumbnail grid picker, renders an inline preview, and offers View/Swap actions that open the image lightbox or PDF viewer (PR #12506).
Enhancement
Block editing
  • Markdown formatting and rendering improved for quotes, code blocks, and headings (66b1140fc9).
  • Breadcrumbs read more clearly when navigating deeply nested blocks (PR #12595).
  • Notice surfaces when block content conflicts arise, flagging sync collisions (d1ac0836be).
  • $ autopair pairs inline math delimiters like brackets and quotes, with $$ block-math handling (PR #12618).
  • Deprecate the legacy ((block-ref)) syntax: imported titles convert block-refs to page-refs, the i18n key drops, and new content should use page-refs (PR #12627).
Graph visualization
  • Task zoom-in view drills into a single task’s neighborhood (d12beff383).
  • Graph view interactions polished; node picker dedupes raw nodes and property choices (9318205c32, cf24914e6c, c8d00f5a7b).
Developer tools
  • CLI gains show --page-hierarchy, show --page library, block/link rendering in show, and more export options (319d07a2e5, 9aa73a1976, 7a731c6044, 7b68c57056).
  • CLI ergonomics: --enable-sync on graph create, longer sync upload timeouts, three-line list output, outdated-skill warning, unified build-version reporting (f5b122ddd5, ca08579d47, 94c942bf7c, 314c68cd9a, 137dd7fefd).
  • db-worker-node restarts automatically on version mismatch and skips direct-pass calls in thread-api routing (2f0a4f37e5, 17ae997013, ca7647f808).
  • CLI agent skills refined; new logseq-review-workflow, logseq-task-on-lambda, and logseq-answer-machine skills added; lambda PRs record URL, link issues, and follow a clearer status flow (14b85b96d6, 55123a65b6 and related).
  • Desktop and CLI backup paths unified (3f5b52cc07).
Plugin system
  • Plugin libs surface refined; plugins pass plain JS objects across the Electron IPC boundary (PR #12588, dfc689d607).
  • Plugin manager uninstalls unused plugins (PR #12603).
  • Legacy plugin storage APIs keep working alongside the refreshed surface (PR #12605).
  • Plugin cards render their own thumbnail icons (5726ecaa21).
  • Marketplace search matches plugin descriptions (not just titles) once the query reaches 3+ characters (PR #12470).
Bug Fix
Sync and storage
  • Snapshot upload payloads now cap; oversized tldraw payloads drop, preventing a single large snapshot from stalling sync uploads (293309801f, 99d2e30066, bba25ea579).
  • Stale sync sessions recover: websocket restarts, in-flight uploads clear on reconnect, downloads resume from correct paths (70042a46df, 6bfb7963d5, 20c7930727).
  • Encrypted sync: RSA key pair cache scopes by server URL, wrong e2ee passwords surface on download, deleted property pairs stop replaying to the server (PR #12586, c19eca0fd6, 05e8d0c435).
  • Checksum and local-tx handling stay aligned between client and server; guard prevents zeroing local-tx; client-ops db is ready when creating remote graphs on web (009d93dc92, 13779a4047, b71228a7b0).
  • Title sync conflicts keep the latest write; downloads restore sync metadata; asset remote-metadata stops being retracted (7c339462d0, 4ce4aedee8, f7ff5301fa).
  • RTC asset sync status reports pending assets clearly (0980e63711).
  • Android graph download regression fixed; local-tx initializes correctly on new graphs (8857be2baf, 2a1ec47b03).
  • Asset upload failures recover; retries no longer silently drop assets (6f5b000217).
  • Stale large-title objects drop from the sync flow (af5683f7c9).
  • External and local asset URLs (including external-url paths and plugin binary writes) resolve correctly (658e672551, PR #12656).
  • Filesystem boundary calls stop throwing on mkdir/stat; IPC error handling stabilized (49dd71d658, 72822bc720).
Search and queries
  • No-unlinked-references behavior restored on pages without references (643979123056).
  • Search returns matched pages again; debounced results stop flashing intermediate state (62eac11fe3, 5bc8fafb1b).
  • SQLite FTS quote parsing fixed; more invalid-FTS cases handled, so quoted or unusually punctuated queries no longer fail (e9ea5ef34c, fe153af811).
Database operations
  • SQLite format validates on import; unhelpful header check removed; flat client-ops layouts import correctly (db84d6bd96, c647326d86, 843dfc78d4, e8de3cc104).
  • GC stops running on client-ops db (no Datascript schema at addr 0) (d619745d30).
  • Desktop SQLite backup path restored; browser DB export unblocked; desktop SQLite binary export now opens in standard tools (627cb619e1, c6ac84cd28, 18c69fe1a8).
  • :block/name stops updating when a custom date formatter changes; deprecated properties handled cleanly when validation fails (69c4d36a61, 9712b1ed7b).
  • Legacy properties drop; db-worker ui-request response args align (e470dfd5f0, ac102e70fe).
  • :ref/default-open-blocks-level 0 works in DB graphs again (PR #12501).
  • Datoms format corrected when repairing invalid data; invalid data from older graphs loads without crashing (c32428702f, 3ae4d92adc).
UI/UX
  • Fullwidth [ IME auto-completion restored for CJK page-ref input (PR #12606).
  • Table view duplicate fields, large-title rehydrate flicker, and pending-new-block tab re-queue all fixed (d8fd169899, c5775df851, 46227b05eb).
  • Focused-root indent/outdent and move ops guarded so blocks can’t be outdented past the zoom root (PR #12583, a544e7f407).
  • Flashcards: dialog stays open after finishing a card; collapsed children load on reveal (1bcd855542, 0d5986eb90).
  • Outliner remaps pasted property value UUIDs; general paste regressions fixed (cea40a2cd6, 540e410320).
  • mhchem reaction arrows render correctly in math blocks (a772e6582b).
  • Calculator CodeMirror expands without scrollbars (PR #12600).
  • Scoped choice actions refined for tag property configs (46ab697178).
  • Shortcuts preview availability fixed; header and NativeTopBarPlugin icon sizes adjusted (PR #12556, cff7f58d46).
  • Keyboard navigation works for installed themes in settings (7018f62bf7).
  • “Sync” paid-feature label capitalized consistently (cecabbf157).
  • Block selection no longer breaks while scrolling long lists (1b9a1999ac).
  • cmdk sidebar shortcut stays scoped to its panel (58098303e0).
  • Heading bullets, heading icons, and dark right-sidebar header align with their content (1c061cc871, 96bf1f074b, 755840c474).
  • Right sidebar accepts asset drops (b2fc00b31b).
  • Order-list sibling-block reactions fire correctly when checking off items (PR #12617).
  • Stale title state clears when converting a block to a code block (4c98cc6b51).
  • Markdown headings render inside quote blocks (PR #12611).
  • FSRS cloze macro renders with superscript and subscript markup (e097ec8cd8).
  • Icon and bullet alignment regression fixed; breadcrumb icon layout preserved on long paths (aef715a525, c10a3b0fca).
  • Breadcrumb labels resolve UUID refs to titles; breadcrumb label class tidied for consistent styling (PR #12636, ee9a667392).
  • Left sidebar favorites truncate cleanly (35aaaba83f).
  • PDF viewer toolbar background no longer blends into chrome (fef89c1c4e).
  • Keyboard shortcut creates missing journal pages (302f798052).
  • Notification payloads carry i18n keys for localized strings (9dbb2ca522).
  • Resized network image width persists on reopen (a20939292f).
  • Spaces between refs in headings preserved (c84e7de0fb).
  • Code block language preserved on round-trip (7838becdf0).
  • Firefox paste lands content correctly (c37386e393).
  • Class hierarchy hides where irrelevant; class label maps resolve correctly (PR #12640).
  • Tag aliases hide from tag completion; the convert-to-alias action hides where it shouldn’t appear; markdown tag link aliases and block refs in merged hashtag links preserved (03adb8c7f8, 2de6597811, 4fe42af3ed, 37789780cd).
Properties
  • Partial property value writes prevented; block property value deletion commits cleanly (fc51c77765, 4e6b9a2225).
  • Scoped node property values run faster in dense graphs; follow-up regression fix keeps scoped values intact (PR #12651, PR #12659).
  • Property config regression fixed; closed values reparent when converting a property type (a034f80f37, 5afaf32378).
Recurring tasks
  • Scheduler honors the three documented repeater cookies (.+, ++, +) instead of applying a single ++-like rule to all (PR #12523).
  • Task choices record reproducibly so repeats don’t drift (5638050cbb).
Graph visualization
  • Deleted recycled nodes clean up rather than leaving stale entries (562e56e4c5).
Developer tools
  • CLI sync status gives an actionable message when no e2ee password is set; sync subcommand hints and config.edn read/write repaired (3943f0b1ec, 49382463cd, 90891fdab7).
  • export-edn regression on deprecated properties fixed; CLI block-ref rendering corrected (6945771612, 1d027cba3a).
  • CLI content options coerce to string (35e335178e).
  • CLI queries reject :db/id datom clauses with a clear error; invalid-query message trimmed; show hides empty property ids; sync upload --help clarified (2a0bf68fa0, e1c5025dd3, PR #12666, PR #12667).
  • Packaged db-worker runtime path resolves; CLI stays usable when the db-worker-node server is unreachable; CLI skills bundle into desktop releases (9e4b8c8246, 7488b92407, c14248c0a9, d6af5d8836).
  • Failed sync downloads on new graphs recover; re-upload works after deleting the remote (12b4c3399d, 07f3006a5d).
  • db-worker starts with template config when its own config is missing; server-list writes protected; repo-name comparison handles db-version-prefix mismatch (4bbb53cdf3, c6d21e2006, 5301d39f07).
Mobile
File handling
  • Electron custom URI scheme links open the right graph and page (PR #12549).
  • Marketplace markdown image tags render plugin previews reliably (8b510ea034).
  • Windows file URL block links open correctly (PR #12646).
Import and export
  • Imports preserve emails in quote blocks; property values referencing custom-format journal pages import correctly (8a7ba2f665, 47407a3d8d).
  • Exports ignore legacy-property entries; copy/paste export property data normalized (a610925bca, 9cfbaf80dc).
  • Imports preserve task statuses, repeated schedules, and namespaced inline tags (f42da95204, 44d6bd49c4, ee6b38b9d6).
  • Auto heading pre-blocks import correctly; mixed quote blocks survive DB export (PR #12612, PR #12610).
  • SQLite DB exports write as binary; client-ops DB export on web unblocked (e03e019a19, 0b26f16422).
Publishing
  • Hidden properties, protected pages, and protected tag listings hide from the published site; public /pages listing endpoint removed (b953a5c92c, e44bd79526, 0b6ec5916c, 0a077d1144).
  • App status icon styles match in publish; legacy short/page URL routes preserved; DO stubs acquired in a sync let to avoid RpcPromise clone failures (c2c5dbee0c, 3a63f09bef, PR #12521).
  • Mixed RTL/LTR pages set dir="auto" for correct layout (f6e2ab9026).
  • Published task bullets clear of the status icon on mobile (127356d753).
Plugin system
  • Electron IPC accepts plain JS objects; i18n interpolate function reference inside plugin code fixed (17a092d438, 5907b09824).
Performance
Search and queries
Refactoring
Graph visualization
  • Graph view rebuilt (V2) for better navigation and rendering on large graphs (PR #12604).
Sync and storage
  • create-remote-graph moves to the db-worker; unused node persist-db implementation removed (72252e5b58, e750c79e34).
  • DB no longer reloads from disk after a remote create; data writes directly into the active DB (40d8442180).
Chore
Developer tools
Upcoming
On feature branches, not yet shipped.
New Feature
Sync and storage
  • Two-way sync between markdown files and the DB graph — additive sync of edits back to DB, ADR 0017, mirror-id sparsification, mirror-property syntax, Logseq Sync compatibility test suite (cd31a39fef, 6cb495ad65).
Enhancement
Developer tools
  • Build pipeline migrating to Vite: replaces gulp, moves UI + plugin SDK builds, switches electron scripts to node, rewrites shadow externals namespace imports (8bf4624a34, 97a30f61d3).
Plugin system
  • Storage path handling and async calls improved in plugin libs storage APIs (7d029ab4aa) .
Bug Fix
UI/UX
  • Property UX: route-root hidden toggle, gated date edit icon, tightened bottom property edit popup (3d96bf9fe3, 2e07fe1b8a).
Contributors
  • A. S., Charlie, Cory Donnelly, Gabriel Horner, Grandroot, hoellen, IderAghbal, ivan-danilov, Kidy Lee, Mega Yu, PlunderStruck, rcmerci, TechnoHouse, Tienson Qin, Victor239, VictorVow, Will Wu, yshalsager
Changelog (2026-05-17 to 2026-06-30)
Spotlight
  • Inline comments — Comment on any block, edit thread titles, and tag comment blocks; the groundwork for collaboration on shared graphs. (0e87a83, 29854b9)
  • On-device semantic search — A zvec vector index finds blocks by meaning, entirely on your machine. (fd1906a)
  • A rebuilt command-line interface — The CLI is rewritten in OCaml/Melange and ships with the desktop release. (0caa286, fabf692)
  • Agent bridge — The CLI runs coding agents from graph comment blocks and reports status and reactions back into the graph. (507a39f, b940287)
  • A new UI foundation — React rendering moves from Rum to HSX and components move to Base UI, with popups, menus, and toasts reworked on top. (d185ea5, e95f1e2)
Released
New Feature
Block editing
Search and queries
  • On-device semantic search powered by zvec embeddings; it is off by default and checks for Python first (fd1906a, ac90b8d, 2be07b1)
Developer tools
  • Logseq CLI rewritten in OCaml/Melange, replacing the old CLI; cli-e2e tests ported (0caa286, c226ffb, 52398ac, dbd220c)
  • CLI agent bridge runs coding agents from comment blocks, stores prompts in the graph, and sets reaction and status while it works (507a39f, b940287, 1712bff, 2f9d137)
  • CLI release builds in the desktop workflow; the CLI resolves db-worker next to its entrypoint and uses the parent executable (fabf692, 5337f89, c7186a7)
  • CLI tag schema properties and a datascript_query type (ddb13c3, 63dbd61)
  • Linux store publishing option for releases (267b3e3)
Settings
  • Partial Vietnamese translation (2ecffff)
Enhancement
UI/UX
  • Gallery view improves (ae2ba48)
  • Show/hide controls for properties (186e699)
  • URLs carry graph identity (ec0c01f)
  • Toasts get a new layout and a dismiss-all action; buttons, radios, and the color picker are polished (4d800fd, 34634ee, 346f0ec, 4e27d8b)
  • Flashcards icon updated (7e2062f)
  • Page aliases enforce strict ownership, and alias search improves (b3c2002)
Mobile
Plugin system
  • restorePage plugin API (77923d6)
  • API rate-limit notices suppressed and a new loader; plugins that clearly don’t support DB graphs are hidden (9f59687, 0057cb9)
  • The component registry is exported globally for dynamic rendering (da05ba0)
Sync and storage
  • Sync onboarding flow improves (466647e)
Developer tools
  • CLI error codes, table header ordering, Unicode-safe auth and output, and stricter option and graph-name validation (2a1f1fb, 64a3f75, 28d5529, ac6f8bc)
  • Desktop release package shrinks (69cb8a9)
Bug Fix
Block editing
  • Number lists work reliably; rapid Enter keeps focus; Home/End/PageUp/PageDown navigate (b743103, 1e9c724, bd1c637)
  • Date picker sets the year and allows repeated selection; start of week respected (49bfb65, 53b7d9c, b3ab321)
  • Released clicks no longer select blocks; asset block editing stabilizes; the add-block button shows on block-rooted views (0596129, b22fa0c, 7f063d9)
  • OG heading refs paste correctly; undo keeps created-by (04fcd02, 2260913)
Comments
  • Comments keep the editor open on save failure, skip submit while composing, copy correctly, and move as siblings (a4e423c, 3a7c25c, 94ccc71, aae14bb)
  • Comment thread metadata repairs; comment shortcut focuses from an editing block; icons align (2efa164, b39adf0, 553f15a, 8e48079)
Properties
  • Property UX regressions fixed: controls and key triggers align, description tooltips work, and tag property spacing tightens (aca15fa, 943d132, b6fec73, a61a4ec)
  • Bottom property pills constrain, expand, and limit per line (6361161, 9e5b70e, 64d9bb2)
  • Bidirectional properties stay visible and listed; number-property groups sort (2b4a87b, 0aad345, 6588d56)
  • Property deletes clean references; value tooltips stay in the page; asset properties stay in the normal area (2202b0b, f14e952, 292f5d3)
  • Setting a status adds the Task tag; assignee property definition fixed (c8ab870, aeeb329)
Search and queries
  • Search keeps canonical page titles and shows titles instead of block uuids; unique block titles are shared (073bbeb, 2df31ef, 0a28fb4)
  • Queries exclude query properties from refs and keep query block fields before hydration (c5ad6ee, cdb63e2)
Database operations
  • Recycled pages leave the sidebar and their children delete permanently; restore goes through outliner ops (d5929a9, ab919e6, c5f0f86)
  • The only demo graph cannot be deleted; today’s journal deletion is clarified (c48b699, 8014dd5)
  • db-worker recovers without graph failover; the DB is not queried before it’s ready (a40b32e, ed1d01d)
Sync and storage
  • Unrepaired deleted blocks, missing db-sync data, and stale asset ops repair (681393e, ffcd0fc, 3173364)
  • Sync stops reuploading remote rebase txs, batches with client revisions, and syncs migration txs (f19340e, 25d2889, 910a76f, 6c28ff5)
  • Sync errors report to Sentry; server tokens normalize; graph transfers guard concurrency (11c4f11, 561a1e5, b2dee8c)
  • Duplicate sync icons removed; the current server subtree deletes cleanly (448f2b8, 9914a3c)
File handling
  • EDN import is idempotent for :url properties, adds no spurious property history, handles datom-based :graph imports, and creates no initial data (0897e45, 6b11608, 3a63877, f839df3)
  • File-graph import hardens and keeps nameless task markers (2c1d0f0, 4a2193f)
  • External assets render and journal imports handle namespaces (d130d72)
  • Export keeps indentation, block selection, and scalar property values (6db2382, e25a41a)
  • Public export builds from the worker DB and skips comments (dacc5dc, ed3be1a)
UI/UX
  • Popups, submenus, selects, and dialogs stabilize after the Base UI migration: scrolling, anchoring, toggles, outside-click close, and z-index (6a992d5, e47c916 and related)
  • Graph view buttons improve; the help button is clickable (13b631f, e6360c5)
  • Breadcrumbs navigate and show a single hidden segment directly (1c7d8b4, 591ca8e)
  • Sidebar recents and lists refresh, including labels after a language change (16d5697, fd5d647, bac20ef)
  • Table row selection and checkboxes work; page refs with icons wrap (c866045, 9f10e40, 3b1d5f8)
  • Avatar initials render for non-Latin usernames; adding and switching graphs are separate actions (6b16efc, 4e317c3)
Desktop
  • Electron proxy agents work (f674fb9)
  • The asset protocol handles PDFs, Windows drive paths, CORS, and audio (c6790c3, 4b5ea57, 42e13ac, 4a5d48c)
  • ESM open-package interop; the CLI launcher installs to local bin, and the AppImage launcher popup is fixed (ef2db0d, e9d66de, 07e81c7)
  • The embedding server handles exits and recreates stale venvs (935e98f, 80aeb07)
Mobile
  • iOS navigation stacks, tab transitions, and search focus stabilize (6dd00b0, 774640d and related)
  • Native iOS graphs view; graph download progress from the switcher (7259ce4, 2b950ba)
  • Block math renders; iOS fonts fixed; asset uploads work (bdc611b, 57131dc, d7955dd)
  • Mobile comment and reaction toolbars; browser back prunes the stack (7d21931, ef7730a, 92b9f39)
  • Android UI/UX bugs fixed (e47f805)
Plugin system
  • Marketplace UI and registered-resource lookup fixed (97e1dfc, 5f5f302)
  • Plugin styles and fonts load from a compatible logseq.io URL; the slow-load dialog is interactive (67376e0, 64e0221)
  • Callable APIs replace exper_request; missing external resources restored (2663d7b, f54a82f)
Developer tools
  • CLI fixes for Windows open_url query params, empty config files, inline block properties, option autocomplete, and graph export options (7cffb3c, 314c0b2, f5d94ec, 3a8c24a, 8b98816)
Settings
  • Brazilian Portuguese search label corrected; missing zh-CN keys completed (19a9294, 3b35fdd)
Performance
  • Startup and indexing stay unblocked, and the graph is marked ready after full-text indexing (479f019, a0ddc44)
  • Journals virtualization stabilizes (550d7ea)
  • Ordered-sibling queries batch; state subscriptions and RTC presence renders churn less (87f9aef, dc3f335, 85b6cd9)
  • Roadmap page renders faster (e0f9e21)
Refactoring
  • Rum replaced by HSX for React rendering, with a Clojure-aware state updater and stable hook order (d185ea5, f44e28d, 8936460)
  • UI components migrate to Base UI (c71cd24, e95f1e2)
  • Frontend state migrates to rfx and splits into modules; missionary removed (3badd72, 92a63a6, 561c965)
  • Graph EDN import/export reworked (5897ead)
  • Redundant class extends cleaned up; pointer-down state APIs renamed (a3837bc, d921807)
Chore
Contributors
@benjypng, @Charlie, @debanjand, @Gabriel Horner, @Jarema, @Mega Yu, @rcmerci, @samwei12, @stephen-abc, @Tienson Qin, @VictorVow
Changelog (2026-07-01 to 2026-07-31)
Spotlight
  • Worker-backed rendering — Pages, journals, and views read from the DB worker incrementally and virtualize, so large graphs open, scroll, and edit faster. (fb1047d, 7914388)
  • Instant journals — Visible journal days load first, blank journal loads disappear, and complete trees fetch on demand. (c3205d4, c923c6e)
  • db-sync semantic REST and MCP APIs — Sync servers expose semantic read and write endpoints for scripts and AI clients. (3d10d64)
  • Sturdier sync — Stress testing drove fixes for stale transactions, checksums, deletes, and missing assets. (f983366, b29e720)
Released
New Feature
Sync and storage
  • db-sync semantic REST and MCP APIs; semantic uploads count as remote assets (3d10d64, 91ea251)
Enhancement
UI/UX
Developer tools
  • CLI bundles tree-shake; duplicate option values survive; agent bridge tasks process concurrently (af9bc11, dd450ba, fc6bc86)
  • Agent bridge comments route from transaction data and candidate blocks (2351270, 023e651, b0f47a3)
  • Logseq server API gets its name (998207f)
Bug Fix
Block editing
  • Rapid Enter, rapid structural edits, and Backspace keep their block structure; empty parents survive Backspace (2971894, c057c5a, 2aff617, 8add930)
  • Undo skips duplicate steps; the moving block stays in the editor; the caret holds during content changes (2f435e9, cd0c276, a4963dc)
  • Focus returns after deleting a block; dragging blocks works again (1400c0c, 59dbf20)
  • Pasted blocks reuse page references; pending edits keep their intent; copy finishes before cut (4d09e6e, 5688dcd, 1c3fd79)
  • Code editor content syncs on property changes; lazy editors keep their height (2da66c2, 52d5113)
  • Worker-backed editing, block rendering, and outliner moves stabilize after the rework (69f945e, cfa48e8, 9381cdf, fbaecc7 and related)
Properties
  • Property interactions, reactive view properties, and page properties refresh correctly (8678d25, a81e5cf, d94e78b)
  • Reference properties keep entity ids; property values normalize and menus select correctly (24f6ef9, 598ef43)
  • Hidden property state reads correctly (3de17c2)
Search and queries
  • Command palette opens pages in the sidebar (b91a4c9)
  • Missing repeat temporal properties no longer break repeated task deadlines (06f1d63)
Database operations
  • Clearing a status removes the Task tag (9c6468b)
  • Tag template refs and template date refs persist, including journal refs (3ffcf23, 1b8688c, 78c9624)
  • Retracting views no longer writes invalid data (bd703dd)
  • Selected export ignores missing nodes; cyclic class inheritance imports are rejected (cf1d01e, 5608603)
  • Block deletion traverses raw children; recursive validation errors no longer print endlessly (9a11243, 3af60d6)
  • Migration tolerates missing comment built-ins (92cf2aa)
Sync and storage
  • Stress-test fixes for stale tx data, scalar UUID strings, empty sanitized deletes, ignored kv tempids, and backup folder txs (f983366, ff2848b and related)
  • Incremental checksums compute correctly; stale pending blocks recover; sync authenticates before upload (f2303eb, 3d45087, bdbfb57)
  • Assets prefetch and tolerate missing files; original upload bytes survive (f180ddd, 09d9ad6, e2b7814)
  • Upload response timeouts report; the cached refresh token restores (d27ab42, 5b87868)
  • Idempotent deletes succeed; derived updates and journal title formats sync from remotes (11fe974, ac2f3aa, 5146256)
  • E2EE password entry submits the current input value (e9f66fe)
  • Graph storage checkpoints when idle; legacy Unicode directories unlink (c452af5, 753a2bc)
File handling
  • Import preserves file timestamps, org titles with middle properties, and nil PDF annotation titles (b09316a, c50b077, d41ced2)
  • Imported journals identify by file path; missing block embeds no longer break import (e9960bb, 86c4784)
  • EDN imports reject invalid datoms; the EDN import input takes focus (4a31954, 053fe1a)
  • Pasted display blocks detect correctly (9e5691d)
UI/UX
  • Linked references group page-level results, pass block UUIDs, and block recursive embeds (c5596fa, e22985a, 6c58d55)
  • Page navigation, recycle entries, and restored entries refresh reactively (89fe270, 9b37e62, 2fee359)
  • Comments keep actions inside the scroll area, refresh threads, and update ownership after login (bfbd9be, e829d5a, 60e4d5d)
  • Popups toggle from the same trigger and animate again; select items show one aligned indicator (71b6f0f, 7e34f6c, 0a2a3b1, cbebf07)
  • Pointer cursors, top-right notifications, and select dropdown indicators return (b08b081, a3f447f, 50163ef)
  • The sidebar loads startup lists after restore and drops a duplicate scrollbar; page icons refresh there (20e5b66, bfce1b2, 83023d6)
  • Theme previews resolve from the stylesheet; background colors highlight on hover; the scrollbar track matches (642cb3f, 4eb07a3, 7b9c463)
  • Page title clicks work again; structural tags hide on blocks; table view actions restore (82142c9, dc31f95, 32d3be0)
  • Quick add keeps a stable block container and awaits the user lookup (9cb4ce7, 893f532)
  • Missing pages render after a worker lookup; the default home validates through the worker (7d9abff, 491db42)
  • Shortcuts refresh after a graph switch restores config (c6c9df5)
Desktop
  • zvec links correctly on Windows (5f2b46c)
  • Packaged CLI and DB graph dependencies install outside the workspace, with pnpm 11 support (5edce99, 868c7b0, cb726c0)
Mobile
  • Cloud graph download popups open on mobile; Android bottom sheets don’t dismiss twice (4975d5c, 2b95086)
Plugin system
  • Empty plugin settings files no longer break plugins (f0d96d9)
Developer tools
  • CLI adds block page refs and awaits sync event subscriptions (2d1f17e, 1719adb)
Performance
  • Page trees virtualize efficiently and journal editing stays responsive (ef02aed, 6582b03, ce5e88b)
  • Journals load visible pages first, reuse loaded trees, batch render metadata, and skip blank loads (c923c6e, c3205d4 and related)
  • Views load visible rows once, prefetch virtualized rows, and avoid full tree hydration (fb96259, 744079b, f7c1bb4)
  • Block hydration speeds up; concurrent block reads share one request (c02f2f7, 9bd209f)
  • Unchanged pages stay valid; discarded descendants and unused window entries are skipped (ed1e23d, d988bf4, 788b5c7)
  • Flat page window updates and deep page traversal allocate less (a11c71d, ca19c0d)
  • Sync batches large transaction applies and avoids repeated delete scans (a38f2a8, 12fc66e)
  • Block list virtualization holds on multiline splits (50a7fdc)
Refactoring
Chore
  • Worker outliner editor review documented; nightly release action pinned to a commit SHA (c54ebfa, 5a23230)
Contributors
@dvorak, @Jianning Wang, @Kobi Hikri, @Mega Yu, @rcmerci, @Tienson Qin, @yshalsager
Changelog (2026-08-01 to 2026-08-31)
Spotlight
  • Faster file-graph import — Importing a file graph parses Markdown outline-first, reads files ahead through a pipeline, rebuilds references once at the end, and shows progress as it goes. (2aee0eb, 9387fe3)
  • Worker-backed rendering settles in — Journals load on demand and the UI, breadcrumbs, and search results render steadily from the DB worker. (64fdf7e, 1b80267)
  • A leaner CLI — The legacy ClojureScript CLI is gone, leaving the OCaml CLI, which now builds with OCaml 5.1.1. (df2623e, bc45731)
  • Video embeds with timestamps — Video embeds improve and YouTube timestamps become part of the note-taking workflow. (336588d)
  • Sturdier end-to-end encryption — Wrong E2EE passwords fail cleanly instead of retrying, and encrypted assets go up to 200 MB. (abdc94b, 16aba8e)
Released
New Feature
Developer tools
Plugin system
  • deleteRecycledPagePermanently API; plugin settings support button actions (a40fd3f, 33333e9)
Enhancement
UI/UX
  • Video embeds improve, with YouTube timestamp workflows (336588d)
File handling
  • File-graph import optimizes parsing with a read-ahead pipeline, a simple-page fast path, and a watchdog (2aee0eb, 597fda5, 197bec5, 2ab8d6f)
  • Import rebuilds references once after all files land, looks up classes by indexed name, and defers the SQLite store until the import finishes (9387fe3, 5ec6bf0, 3bf3f42)
  • Import shows reactive progress, starts the UI in an Importing state, and defers search indexing (f86f954, 7e438af, 3dd55f2)
Sync and storage
  • Encrypted assets up to 200 MB (16aba8e)
Developer tools
  • The legacy CLJS CLI is removed (df2623e)
  • graph validate exposes errors as structured context (f4422e9)
Bug Fix
Block editing
  • Block structure holds at editing boundaries; deletion and undo history stay consistent (02b004e, 223f755)
  • Editor exit and save rendering stabilize (4dbab42, 8970126)
  • Cut finishes before the selection clears; embed placeholders resolve on block selection (f7362f0, 79cc868)
  • Enter no longer splits page titles; the first empty journal block keeps focus; stale editor titles don’t come back (7c7efd2, 8bcc46b, 52378ac)
  • Node ref completion works again; autocompletes no longer receive nil content (db5560b, 2769008)
  • Block macro arguments expand (807cf2a)
Properties
  • Children can’t be added under URL property values; text property value children export (6e7707b, a600fcf)
  • Hide-by-default properties show up in search, with hidden visibility scoped correctly (07d1a00, de070c1)
  • #Task isn’t added when a child class already provides it (c37c76b)
  • Class properties refresh when a tag gains a new property (acfd412)
Search and queries
  • Quoted page references survive in queries (acc75f5)
  • Query function results render without crashing, with render errors isolated (2c6cbdb, e40d839, 627f08f)
  • Page reference search includes public built-ins (cc12422)
  • Search results in the command palette stabilize (8be8b7b)
  • Query cache keys stay stable for right-now-ms (4f21d06)
Database operations
  • Existing journal references are reused (3d2acb0)
  • The Markdown mirror writes TODO for the default task status, resolving status from the entity (aaf189f, cc30891, fbf5e0a, 62c1e36)
Sync and storage
  • Invalid E2EE passwords are handled without retry loops (abdc94b, 3497784, 4c141d2)
  • Mobile RTC sync triggers are restored; RTC doesn’t stop before the DB worker is ready (2f0f2b1, 4d039ea)
File handling
  • File-graph import full-parses headings with properties, list-item quotes, and blocks that need the AST (fe81f01, 02530c6, d1673a3)
  • Import indexes page names incrementally, keeps existing classes as classes, and writes page-drawer refs (61684aa, 8a756c9 and related)
  • Import keeps OG favorites with page refs and namespaces, and file links with formatted labels (3745c5d, 5f2e365, b2084f5)
UI/UX
  • Journals load on demand; journals, pages, and breadcrumbs render steadily from the worker (64fdf7e, 781ecb3, eb8bb3c)
  • Worker-backed rendering stabilizes, with renderer invalidation and mounted children kept across revision gaps (1b80267, 5ff866e, 67d8c2f, 55db336)
  • Table row selection actions return; deleted pages leave recents (bc7783b, 88f7d61)
  • Tag icons inherit on page references (fab2774)
  • Cover asset fields stay on view rows (c0cd46b)
  • The window title updates on back navigation (9ee6129)
  • Header shortcut tooltips stabilize; the toast close button shows a pointer (a598e81, f079b36)
  • The sidebar and settings follow language changes (53d43aa)
  • Issue links point to the db-test repo (d2365a0)
Desktop
  • Each MCP session gets a fresh MCP server (71db2e3)
  • Spell check recovers after a Linux restart (11c0dcd, e5cc2f6)
  • Hot reload serializes its lifecycle (b2dcb1f)
Mobile
  • App startup and journal rendering are restored (cc19f05, 2de9d29)
  • Android native sheets render content before presenting, sync with the header, and reuse the open sheet for nested popups (2d86e76, 047acf3, be7c1d1)
  • Android respects the status bar safe area (fa919cb)
Plugin system
  • Plugin settings no longer crash; custom uuids work in createTag (ddfcbd5, edc934b)
Developer tools
  • CLI zsh completion regressions are fixed, including --graph= completion and repeated --fields (71d9ab6, 2934597, d823f7b)
  • graph validate drops a nonexistent --fields option (5ff4e02)
Performance
  • Import parses Markdown with parse_outline_only and reuses page-ref and property-drawer ASTs (27e11e9, 6a0d033, ed8a2e9)
Refactoring
  • Frontend state unifies in one re-frame db; UI DB worker flows simplify (f144637, 3bae14d)
  • Worker render state, subscriptions, and snapshots streamline; the worker metadata cache is removed (967c330, d81317b, 0cfb7bc, 30cafd4)
  • The import path simplifies around the read-ahead pipeline (197bec5, c7763ba)
  • Unused db-sync cycle repair and radix tabs are removed (39b4311, a8c9c0a)
Chore
Contributors
@Arthur, @Aung Min Myat, @Chip Nowacek, @Danny Pham, @debanjand, @Gabriel Horner, @Mega Yu, @Mike Burton, @rcmerci, @Terwox, @Tienson Qin, @Yuzhong Zhang
