Logseq sync and "quick capture"
Hi,
Sometimes when I use “quick capture” or sharing from ipad or moble app, current journal or daily one is deleted if I put some content in other device before.
So I think that Logseq must First Sync and then Create the “quick capture” entry.
Is it a bug, do I need to create in the right section?, I don’t want to create noise or make things wrong.
Thanks.
hey @Jose,
Yes you are correct. This is a known issue and the Logseq team is working on a solution for it.
Thanks a lot for your response @Bader.
