- Synthesis is meant to both simplify and improve plenty of other things, thus superseding them.
- As long as someone is willing to afford the potential overhead in installing, learning, and using it.
- In other words, configuring is not enough in itself.
- Smaller focused threads are preferable to long gathering ones.
- The dedicated subforum is a good-enough gatherer anyway.
- Tags could be used to further group related threads.
- Big meals should be eaten in small bites.
- Baptism in basic lessons is necessary before diving into practical usecases.
I understand that one can use/call any program Logseq supports to do something and then define a “natural” language so that that specific “something” can be achieved using whatever form of natural language is covered in the corresponding definition patterns …
With existing info I can grasp the usefulness for evalonce (as per my previous question, to render a macro inside another macro - ex: [Luni]( {{macro-name var1 var2 etc }} ) so I guess one would write it something like this: {{evalonce [Luni]({{var this monday}})}}?
I can also see the potential to have a macro to create an empty Xcolumns x Yrows Markdown Table where Cells can be edited without going to block edit mode, in a “live” manner. I have no idea yet how that could possibly be triggered ({{evalonce table, 4x3, zeroed}} ??)… Another idea: importing a CSV into a table ??
I am also curious how can this be used to:
- make a natural language querying environment, where complex queries are created behind the scenes from the natural language provided to the macro… ;
- creating multi-block “templates” just like we can now call the (single)block templates;
- call templates from an evalonce so the daily template would just contain an evalonce call that calls Weekday template if it’s a week day, Weekend template if it’s weekend, etc … (?)
I can’t wrap my head around how the above would work and even if my assumptions are correct so I am eagerly waiting for any discussions/examples/videos that anybody would post so we better understand how this works and what is possible.
- Everything you mentioned is possible.
- Some of them already tested and working.
- Some of them needing some integration (e.g. file system stuff).
- Actually the current problem is the inverse (i.e. how to prioritize among the endless possibilities).
- But this is not just “a better macro”:
- Forget things like
{{evalonce [Luni]({{var this monday}})}} - Should instead look like
{{evalonce link for text "Luni" and url (date for this Monday}}- Could still compress it to less and shorter words, but that’s not the point.
- Could even have an old-fashioned macro make a call to Synthesis.
- But the true power is in synthesizing smaller functionalities to:
- automate most of the boring part of your work
- abstract the generation of whole interfaces
Ideally when I write Luni during writing a text the system would have already made it into a markdown link just as we can do with text expanders :Luni goes straight to link but even without having to think about it.
Other automation I can think of is automatically populating some properties of my blocks. I use a dozen block templates to capture anything from Logs to Info to Video to Book to whatnot and I have a certain number of properties that go with each input data and I would like to define somewhere in Logseq:
- if the block is of type “Info” and any word inside the Header of the block contains something that resembles a namespace, put that as the namespace property, otherwise look for some page-name inside my graph and, if it resembles that page-name, put that as “related-to::” property. If nothing is found in the header, move to the block body… and so on. Automatically filling some of the properties would drastically cut my time setting up each block. Ideally an AI-type thing that learns from previous such cases and helps with this meta-data “guessing” would be the thing to have;
Each user has his/her own set of automating needs and they will still have to learn to implement them if they are niche…
This is a most excellent project. Thanks for making it available to us.
For my use-case I’ll cross-post from another thread
I took a slightly different approach to this problem by reusing code from the custom macros that replace themselves thread.
My use case
- I wanted a scheduled task to automatically appear on my journal page each day reminding me to take some vitamins.
- I use Logseq on both mobile and desktop
So I wrote a macro {{schedule-date-today} }that replaces itsself with SCHEDULED: <todays date> when and only when it is evaluated on a journal page. Otherwise it just behaves as a normal macro.
Environment
- I use
:default-templates { :journals }to load a template to the daily journal. - I use kits to run custom javascript.
configuration.edn
:default-templates { :journals "daily-journal" }
:macros {
:schedule-date-today "<div class='kit' data-kit='expandmacro'>||scheduled today||</div>"
templates.md
- daily journal template
template:: daily-journal
template-including-parent:: false
- TODO {{icon ef63}} Take vitamins
{{schedule-date-today}}
The :schedule-date-today macro directs kits to run the javascript in the code block contained in the first child block of the page expandmacro.
expandmacro.md
```javascript
logseq.kits.setStatic(function expandmacro(div){
const blockId = div.closest(".ls-block").getAttribute("blockid");
const block = logseq.api.get_block(blockId);
const pageId = block.page.id;
const page = logseq.api.get_page(pageId);
const pageIsJournal = page['journal?'];
if (!pageIsJournal) { console.log('is not journal'); return; }
// This date is in the org-mode SCHEDULED format
const date = new Date();
const day = date.getDate().toString().padStart(2, '0');
const month = (date.getMonth() + 1).toString().padStart(2, '0');
const year = date.getFullYear();
const dayOfWeek = date.toLocaleString('en-US', { weekday: 'short' });
const formattedDate = `${year}-${month}-${day} ${dayOfWeek}`;
const content = block.content;
const macroStart = content.indexOf("{{" + div.closest(".macro").dataset.macroName);
const macroEnd = content.indexOf("}}", macroStart) + 2;
logseq.api.update_block(blockId, content.slice(0, macroStart) + `SCHEDULED: <${formattedDate}>` + content.slice(macroEnd));
// {{schedule-date-today}}
Has anyone noticed the macro being run too soon? I have a macro to replace a ticket number with a link using the ticket number in both the description and URL, and sometimes it starts running the macro before I can finish typing the ticket number. Sometimes it looks like it runs several times really mangling up the link.
Welcome.
- Yes, this can happen to any macro, it is not specific to this kit.
- Macros run every time a block is updated.
- Kits don’t control macros execution.
- Some heavy combinations (e.g. embedded blocks) cause more updates than they should.
- Therefore also more macro executions.
- It is not easy to consistently reproduce the problematic behavior.
- Does this happen with all your macros?
- If you come with an easily reproducible scenario, I could potentially come with some workaround.
Thanks! This made me think a little bit about it. I was able to reproduce one facet of the issue – if I happen to have the same block in the side bar (shift + click) then it does get unpredictable.
The macro itself is dirt simple:
:jira "<div class='kit' data-kit='expandmacro'>[$1](https://myjira/browse/$1)</div>"
e.g. {{jira SOL-9999}} is supposed to be replaced with
[SOL-9999](https://myjira/browse/SOL-9999)
but if I have the same block open in the right side bar, i.e. shift-clicked on the block, I get:
[SOL-9999](https://myjira/browse/SOL-9999[SOL-9999](https://myjira/browse/SOL-9999)SOL-9999](https://myjira/browse/SOL-9999)
I will try to note what tabs I have open when I see the other issue where it renders before I finish typing out the macro. It may be good enough to put a sleep statement in there or just don’t have the same block open in multiple places.
Try this variation:
const ongoing = {};
if (ongoing[blockId]) return;
ongoing[blockId] = setTimeout(()=>{delete ongoing[blockId]}, 500);
const content = logseq.api.get_block(blockId).content;
OK so I’m just diving into this and I’m really stoked. It’s what I’ve been wanting in Logseq for a while and not been able to get. This has really reinvigorated my love of Logseq and getting it to work the way I want. Thank you so much @metaloid.
The first hurdle I’m hitting though is what commands are available to me. I can see from your example I can do stuff like .api.get_block and .parent but where should I be looking for the rest of them. A few examples. (I’m not expecting an answer to all of them this is just to give you an idea.)
- I was interested in getting the logseq usable reference for a given block e.g. ((683c1cfb-90c5-4f5f-8b13-e5d3201355c9)) like you get when you click ‘copy ref’.
- How to access the previous or next sibling not just a parent block.
- How to pull whatever’s stored in the clipboard.
- How to append info to a block.
I appreciat that some of those things might not have a built in command but I expect that some do.
I’m assuming it’s somewhere in the code in github but I’m not really good enough to know where to look.
Could you point me in the right direction please.
- These days such directions can be given by LLMs.
- The available “commands” are called API.
- Logseq’s API is described here.
- The actual API is accessible from the console (
Ctrl + Shift + i) withlogseq.api
- Direct data may not have such “commands”.
- For example, the previous block (whether sibling or parent) is available as
:block/left - Some data are not even stored, because they can be queried or otherwise calculated.
- For example,
:block/rightis not stored.
- For example,
- Other APIs (e.g. the clipboard) are specific to javascript or the browser.
- Yeah, it’s a lot of stuff (so also hurdles), thus should be faced one-at-a-time.
