- I am running into the issue that page properties always need to be at the top of the page to be recognized as page properties but sometimes that is quite inconvenient. I would suggest a solution to make page properties available all over the page by using 3 (three) ::: to assign them instead of the current two that gives a block property.
- So even in one block you could create a mix of page and block properties (through CSS you might even make them somewhat different to easily recognize them).
- It might be a hit on performance as all blocks need to be parsed in a query intead of only the first one but I thought I put it out here.
Not sure if ::: would be the correct way to indicate a page-property. But at least make it possbile to have page-properties outside the first block.
