When I create a page using namespaces, for example if I have [[ProjectA/Sprint1/Standup]]
and [[ProjectA/Sprint2/Standup]]
the desired behaviour of the graph would be I have two Standups which are unique in the graph. That means the node at the last page should be projecta/sprint1/standup
then the parent node should be projecta/sprint1
and the parent should be projecta
In the current version, projecta/sprint1/standup
is linked to sprint1
not to projecta/sprint1
. I don’t think it’s ideal to have a page called [[sprint1]]
(unless it’s necessary for creating the database?)
Also, it would be good that the last node automatically creates a block which references to the parent for easier access.
