Have you guys seen the latest update of Remnote (after their massive redesign), for example? What they’ve done is quite ingenious - check out their video here on flashcards: RemNote Update v1.4 - YouTube
In a nutshell, you can basically create all types of cards very easily:
Forward cards: Question >> Answer
Backward cards: Answer << Question
Bidirectional cards: Question <> Answer
Descriptor cards: Description ;; Back side
What I love is what they did with Multi-line, which is basically:
- Question ::
- every other answer becomes a point
- this is also another answer
I think the visual aspect with the arrows are great. This far exceeds needing to tag something with “#card” - creates a LOT of friction (you don’t realise how much friction that is until you have to deal with 10,000 cards).
