Hi!
I like to have a link to the next and previous day in journal entries without having to set that manually.
Now and then I review all entries of a month, and I am doing that with the Journals’ calendar plugin.
It would be handy to have a link to go directly to the next and previous day.
Cheers
Dirk
Hi Dirk
You can use the keyboard shortcuts:
- g n: goto Next day
- g p: goto Previous day
Hi wvenator
This does not work for me on Linux.
I tried “g n” with either “Ctrl” or “Alt” or “Windows” key.
Any ideas.
Apart from that an additional link would be great as well.
Cheers
Dirk
Found it, you do not have to be in “edit mode” for the shortcuts to work.
Dirk
