Hi,
I’m using Logseq Desktop version and I’m having problems with the refresh (scanning) process:
- If I store too many or large pdfs (hundreds of MB per file) in assets directory. Logseq always crashes while scanning. If I remove some pdfs, it finish but it’s very slow (can take some minutes)
- Another problem is that closing can take a lot of time and sometimes it never finish so I have to kill the program.
- If I move assets directory to another directory outside Logseq’s graph directory, it has no problem refreshing and it does the job very fast (sub-second).
So I think that the problem is that Logseq is scanning (indexing?) the assets folder for no reason. Is there any way to avoid/fix this?
I have tried assing “assets” to the :hidden option with no success.
PD: My current solution is to move out assets directory before pressing “refresh/reload” icon, and after that move back again.
