Hi,
since my only way to use logseq on my work laptop is by using the web-app, I wanted to ask if it is possible to self-host logseq with plugins enabled?
I was able to use the use the docker image for self-hosting, however, I was wondering if it would be possible to enable the plugins? Or if there is a way to compile and enable the plugins? Or are there technical reasons why this won’t/can’t work?
Best
