Just updated to the DB and there’s a settings bug. The pop up panel isn’t covering the underlying UI.
Im also using version 2.0.1 and I havent encountered this. If you can reproduce this on an empty graph with no plugins , then submit a ug report to logseq/db-test: Used for Database version test specifying your OS. Also try to reproduce it on the web app https://app.logseq.com/
