Shortcut conflicts with existing shortcut null
Trying to set changing to document mode to ctrl+d. Getting an error
Try re-indexing the graph
I just tried that and unfortunately it still gives that error. Even uninstalling all plugins and trying again, the error persist.
The problem seems to be that ctrl+d is also assigned to another shortcut, one that doesn’t exist. Try searching in the settings.edn file if it is assigned to something
I don’t have settings.edn, just config.edn. But there’s only two shortcuts set there and they’re not ctrl+d. Same issue happens on my macbook.
