Is there a shortcut (or a way to assign one) for scheduling a task for tomorrow? I know you can do TODO my task /tomorrow
but that only creates a reference. I’d love if there were an equally simple way to assign a task to tomorrow’s date.
I don’t think there is a slash command for this. I can think of two workarounds:
- On desktop you can press “ESC g n”, which is “go to next / tomorrow journal entry”, and start typing the TODO there.
- You can also use the move block plugin to move the TODO, it has an option for “tommorrow journal entry”. But this plugin is pretty mouse heavy.
Can try either the
Quick Todo plugin
Trigger the quick todo shortcut. Key in your task and include a back link to tomorrow’s date.
DateNlp plugin
Trigger shortcut to go to tomorrow and key in the task
thanks! it looks like DateNLp
will solve my issue
