After upgrading to Ubuntu 24.04, Logseq would not start.
It shows the following message:
[8571:0523/172157.422657:FATAL:setuid_sandbox_host.cc(158)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I’m aborting now. You need to make sure that /tmp/.mount_LogseqbGd1uf/chrome-sandbox is owned by root and has mode 4755.
Trace/breakpoint trap (core dumped)
A quick fix is to start Logseq with the --no-sandbox option.
I guess that the sandbox is there for a good reason, so the --no-sandbox workaround is not a good solution on the long run. The “clean” solution seems to be (according to the Ubuntu Release Note linked above) to “Confine [the] applications with an AppArmor profile.” But unfortunately, my understanding of Linux kernel security is too limited to come up with such a solution.
Can you try with Flatpak? I’ve tried to convince Logseq dev to make it the supported way to install Logseq on Linux and provide the AppImage for dev/testing purposes only (as it should be, AppImage is a very bad way to ship apps to Linux, generally used by Electron-based apps that mainly target Windows and MacOS, because Electron makes it easy to build an AppImage; Flatpak on the other hand is the proper and Freedesktop-supported way to install third-party apps like Logseq on Linux).
AppImage not working on Ubuntu would be an additional argument in favour of Flatpak, in case it works out of the box:
