2 way Anki-Logseq flashcards Sync
I hope this will be added to the DB version , Where I can sync back & forth btw my anki & logseq , It should has the following :
  • sync the card with the tags , images …etc to a specific deck , prompts me to choose the deck & tags when syncing.
  • sync back the data of a card from anki to logseq so If I would like to practice my cards in Anki, I can b/c all the SRS stuff is synced w/ logseq SO i wouldn’t have to choose to ditch either one of them .
rn, there is a great plugin to sync cards to anki but no 2 way sync (Thank You So Much for the ones did it b/c w/o i would not even consider logseq to replace Obsidian)
I tested the db version the public one in github , really nie u added the SRS buttons but still no custom SRS settings like anki is very Lacking …
