Hello community
I don’t understand how to add decimal values. My query seems correct because the addition result is exact for integer values. But as soon as I add a decimal place, whether with a comma or a period, the result is strange
Thanks for your help
- Achat de fournitures
montant:: 15
- Déjeuner d'affaires
montant:: 20
- Frais de transport
query-table:: false
montant:: 10
- #+BEGIN_QUERY
:title "Somme des Montants"
:query [:find (sum ?v)
[?b :block/properties ?p]
[(get ?p :montant) ?v]]
Welcome. That is a tricky problem. Try this:
{:title "Somme des Montants"
:with ?b ; prevent identical values from counting only once
[(get ?p :montant) ?m]
[(* 1 ?m) ?v] ; convert ?m to actual number
Pay attention to the two comments.
thank you very much @mentaloid ,
you’ve solved my problem for the example i gave. but my project is to enter the property ::km (for mileage) in the daily journal note. I’d like to calculate my mileage allowance at the end of the year. The query doesn’t seem to work for this use but I can’t figure out how to modify it… Maybe because I don’t know anything about coding…
@mentaloid don’t take my message into account, I’ve solved the problem by putting a period instead of a comma in my values. The problem has been solved, and thank you for your quick response.
excellent week
