Roam has a new feature that Logseq should copy: putting [[roam/template]]
in any block creates a template with all child blocks. So if I have:
- Daily checklist [[roam/template]]
- look at to-do list
- pick first task
- do first task
Then I type ;;
in a block, a pop-up menu comes up with the templates including “Daily checklist”, and then continuing ;;D
and enter
will result in pasting the above, including children.
This would be convenient for all sorts of repetitive templates and tasks!
Actually logseq has had templates since September : https://logseq.github.io/page/sep%2023rd%2C%202020
You create your tree structure or properties then right click the bullet and choose ‘make template’ then give it a name. To insert a template, use ‘/template’ and pick the template you’ve created.
Well, it seems that for me feature requests are a great substitute for actual documentation!
There’s a bug for me in templates. Does anyone else get this? If I type /Template
and then hit enter on the template item /Daily notes
, it puts the template on the page in markdown form with ###
rather than bullets. If I just leave the cursor there rather than hitting enter
, every 5 seconds it will then add the template items in blocks below the markdown over and over until I hit enter
again. This happens if there are already blocks on the page and using local folders, and continues even if the window isn’t active. Looks like this:
Is this a known issue?
Also, is there anyway in logseq to see a page listing all of my current templates?
Yes documentation is still lacking for now, you can find a lot of tips in the changelogs though.
The templates issue looks like a new bug, you should maybe file a github issue?
There is a query to find templates on the discord channel, I’ll post it tomorrow if no-one replies by then (I’m away from my pc right now).
I don’t use it much bc I store all of my source templates inside the same document for ease of access, maybe it can work for you too?
here’s the query to retrieve templates :
{:query [:find (pull ?b [*])
[?b :block/properties ?p]
[(get ?p "template")]]}
With the latest query DSL, you can use this query:
{{query (property template)}}
