It would be very usefull if logseq would have command line aguments.
logseq [path]should open the given path as the logseq project.--helpshould list all options- list options that influence electron runtime like
--disable-gpu
logseq [path] should open the given path as the logseq project.--help should list all options--disable-gpu
