I have that set to false (the default actually) and you still see this:
It would just be “cleaner” if they got removed automagically.
Also for things like the journal with default queries and things below them it keeps everything tighter together.
Oh! I see. I actually rely on that with my journal template. It is a placeholder for content that I produce during the day.
With that said, I would rather not have logseq strip out those empty bullets within populated ones.
I usually do a quick selection of those empty ones I don’t need when done editing, and delete.
Yeah, that’s why I was thinking it could be a config option.
I also have empty (usually only one, but sometimes more) blocks below headings in my daily template, but that’s also why I was thinking it would remove them after some action.
But this brings up a good point… You (probably) wouldn’t want them removed from an actual template.
