Are there any linux bods here who could help me with how to get LogSeq to show up in the launcher on a chromebook. I know I have to create a .desktop file and put it in the appropriate place. What I’m struggling with is what should be in the file and where to put it
At the moment I have to open a linux window and run the application manually.
Any pointers gratefully received.
Logseq Web version - create PWA:
ON Android phone
Open Logseq.com on Android Chrome. 3-dots menu | Add to Home screen.
ON Chromebook:
3-dots | More tools | Create shortcut
PopUP: Open as Window
Pin to bar
Logseq Desktop version
ON Chromebook LINUX:
sorry can’t help as I haven’t enough space at the moment to enable Linux & install Logseq desktop version. When I do I’ll try and follow these instructions: google_support
Hopefully somebody else will chime in …
Thanks ichmoimeyo. I’ve successfully created a .desktop file for the Obsidian electron app but copying and editing it for LogSeq didn’t work. There is obviously some subtle difference I’m not aware of.
