Hi!
I am able to add a column by adding a new property to block/properties
using the update
and assoc
method using :result-transform
in query that pulls all block properties ((pull ?block [*])
) like this:
(sort-by (fn [b]
(get b :block/scheduled)) result)
(map (fn [m] (update m :block/properties (fn [u] (assoc u :scheduled (get-in m [:block/scheduled]) ) ) ) ) result ) )
→ In this example, I am able to create a column called “scheduled” which shows the value of :block/scheduled
However, when trying to calculate the count of days between :today
and :block/scheduled
, logseq won’t display/add any column for it:
(map (fn [m]
(let [days-difference (dayjs () .diff (dayjs (get-in m [:block/scheduled])) 'day')]
(assoc m :days-difference days-difference)))
result))
→ My expectation with this code: a new column named days-difference
would appear, at least.
- Doesn’t logseq support
let
? - How about
dayjs()
If these methods doesn’t work, how should I approach this?
Thank you.
