When we use the “save as” option on a block, it lets us pick to keep or strip the dashes/bullets. I would like to ask for an additional option: strip only top level bullets.
Consider the following example:
- This is me writing an article
- # This is the article title
- I'm writing some stuff here, it's basically the article content
- ## Here, I'm adding a subtitle
- As you can notice, I'm not indenting anything since this is effectively a long-form article, however:
- if I want to make a list, I would indent it
- if I export this block, I want the dashes stripped from the top level, so it becomes a "normal" Markdown file
- however, I would like to keep the dashes under this indented list
- currently, I don't have that option: it's all or nothing.
I feel this simple change would be a step towards using Logseq as a writing tool.
