Adjust wide mode in settings
Logseq has quite wide margins on the left and right, which limits the amount of content shown at once. Dynalist however has Narrow document layout switch which is on by default and gives similar margins to Logseq, but can be disabled to minimise the margins and fit more text.
Try clicking t w when in non-edit more (press esc.) this should activate wide mode which reduces the margins significantly
Oh nice! Thanks for that. I’d like for the wide mode to be a bit wider though, so maybe an option to adjust it in the Settings menu?
