Hi there, I’m learning the advanced queries and already read the docs on https://docs.logseq.com/#/page/advanced%20queries,
however I still need to dive into the view and result-transform, coz seems everyone is using them quite good but I’m not understand what they are and how they work, besides, I can’t find any docs for view and result-transform, it would be great if anybody can offer me a specific doc.
Actually most people don’t even touch them, because they are hard (in multiple ways).
There is no detailed documentation for advanced queries, much less for :view and :result-transform .
- They both:
- are provided with the results of the previous stage
- process them with clojurescript
- pass their own results to the next stage
- here is the order:
:query→:result-transform→:view→ render
- What they need:
- Some programming knowledge
- of the functional paradigm
- Much reading of examples found in the community
- Thankfully, plenty of material has been gradually accumulated
- but it is not organized
- A lot of practice
- It is hard to even make them work
- No mistakes are tolerated
- Tones of patience
- It is even harder to get what you want
- There is no intuitive debugging
- In other words:
- they are not for everyone
- although they are powerful
- they can do things that are impossible without code
- Unfortunately, they don’t currently provide the full library of functions.
Hello, this is the only page that fits my question, I would like to perform the following query explained in natural language, could you give me some guidelines how to implement it?
- search every block has the “mytag” in predefined list property “tags”, for example we could have a result of cardinality N
- for each of the N block get the value of a property named “myprop” and add it ( I am obviously thinking about this value as a page because logseq automatically created it ) to a temporary list excluding duplicate ( ie: like a a set in another language without duplicates)
- after the foreach we will have a list of cardinality M
- the result should be assigned temporary list of cardinality M instead of the former founded block list ( cardinality N )
Thanks
- Do you want a list of the unique values in property
myprop::of pages taggedmytag? - Are these values references or plain text?
Hello ! thanks for quick answer
yes
they are references because when i put in predefined
tagsproperty on blocks logseq renders them like a link both I write them in text or with #tagnotation , and you can follow as link
In other programming language is very easy , I spent hours in finding a solution ![]()
Thank you so much
- To get a list of unique whole values, try this:
#+BEGIN_QUERY { :query [:find ?myprop-vals :where [?tag :block/original-name "mytag"] [?b :block/refs ?tag] [?b :block/page ?p] [?p :block/properties ?props] [(get ?props :tags) ?tags] [(contains? ?tags "mytag")] [(get ?props :myprop) ?myprop-vals] ] } #+END_QUERY - Try adding to the above query a proper
:view, if you want to get the unique:- references:
:view (fn [vals] (for [d (distinct (flatten (map (fn [val] (into [] val) ) vals ))) ] [:div d] ) ) - words from within plain text:
:view (fn [vals] (for [d (distinct (flatten (map (fn [val] (clojure.string/split val " ") ) vals ))) ] [:div d] ) )
- references:
Hello, sorry for the delay, we had a full week, in the next days I will try
Hello , it partially works , some small fixes were needed but a good starting point !
I answered “yes” at point 1, but it was wrong, I’d have had a list of the unique values in property myprop:: of block tagged mytag ( not pages … )
[?b :block/properties ?props]
Thanks you, I need to understand better the internal logseq db schema
One more issue, i need to split by regex (clojure.string/split val "\s+,\s+") but I get invalid query
- Regex is normally done with
re-patternandre-find - Where are you trying to use
clojure.string/split?- Most clojure functions are not currently supported inside
:where - They are supported inside
:result-transformand:view
in the previous suggested view
:view (fn [vals]
(for
[d
(fn [val]
vals
[:div d]
Check the escaping. You may have to use double backslash \\
