Hi all,
I’m trying to build a query that returns any block that contains two specific references.
I will illustrate it with an example:
BLOCK 1:- [[Topic A]]
- Something important related to [[Topic B]]
BLOCK 2: Something important related to [[Topic A]] and [[Topic B]]
In this example, I would like to build a query that only returns blocks that contains [[Topic A]] and [[Topic B]], so in this example, the query would return just BLOCK 1.
I’ve tried using a simple query {{query (and [[Topic A]] [[Topic B]])}}
but in this example, it would return both BLOCK 1 and BLOCK 2.
It seems that simple queries always look in the whole branch, which is not what I need.
So I’ve started learning some advanced queries, but I couldn’t build a query that works.
I’ve tried the following queries:
[?b :block/refs ?p]
[?p :block/name ?n]
[(contains? #{"topic b"} ?n)]
[(contains? #{"topic a"} ?n)]
This one does not return any result.
[?b :block/refs ?p]
[?p :block/name ?n]
(and [(contains? #{"topic b"} ?n)]
[(contains? #{"topic a"} ?n)])
This one throws “block render error”.
I am not sure if this “and” operator is valid.
Does anyone know if it is possible to build a query to meet these needs?
I’ve put a lot of time and effort into trying to figure this out, so I would appreciate any help.
