At great expense to my sanity, I’ve written an advanced query that sums up its child blocks as timecard entries and displays them as a table and a total at the bottom.
Is it possible to update the title dynamically? In my case I’d like to show the timecard total when the block is collapsed.
My research tells me no, it’s not possible, but I’d like to ask here in case I’m missing something and to document the need for future generations.
{:title "Timecard"
:query [:find ?content
:in $ ?current-block %
[?child :block/parent ?current-block]
[?child :block/content ?content]
(time-content ?content)]
:inputs [:current-block]
:rules [
[(time-content ?content)
[(not= ?content "")]
[(str "\\s*(\\d{1,2}):?(\\d{2})\\s+(\\d{1,2}):?(\\d{2})\\s*") ?pattern]
[(re-pattern ?pattern) ?regex]
[(re-find ?regex ?content)]]]
:view (fn [results]
(let [pattern (re-pattern "\\s*(\\d{1,2}):?(\\d{2})\\s+(\\d{1,2}):?(\\d{2})\\s*(.*)")
h-to-m (fn [h]
(* h 60))
format-duration (fn [mins]
(str (quot mins 60) "h " (mod mins 60) "m"))
format-time (fn [h m]
(str (if (< h 10) (str "0" h) h) ":"
(if (< m 10) (str "0" m) m)))
processed (for [content results]
(let [match (re-find pattern content)]
(when match
(let [[_ start-hour start-minute end-hour end-minute note] match
start-h (read-string start-hour)
start-m (read-string start-minute)
end-h (read-string end-hour)
end-m (read-string end-minute)
start-total-mins (+ (h-to-m start-h) start-m)
end-total-mins (+ (h-to-m end-h) end-m)
duration-mins (- end-total-mins start-total-mins)
formatted-span (str (format-time start-h start-m) " → " (format-time end-h end-m))]
{:span formatted-span :duration duration-mins :note note}))))
valid-entries (filter identity processed)
total-mins (apply + (map :duration valid-entries))]
[:div
[:table
[:tbody
(for [entry valid-entries]
[:tr
[:td (:span entry)]
[:td (format-duration (:duration entry))]
[:td [:em {:style {:color "gray"}} (:note entry)]]])
[:tr {:style { :font-weight "bold" :background-color "green"}}
[:td {:style { :width "1%" :white-space "nowrap"}} "Total:"]
[:td (format-duration total-mins) ]]]]]))}
