Attempt at a WYSIWYM edit mode. Best way to replace the default textarea?
Hi! To preface this, I’m not a web/javascript developer, though I managed to piece together a working WYSIWYM editor. The way it works is by replacing the default text area with a CodeMirror editor.
I just wanted to ask what is the preferred way to do this, maybe with the plugin API? Right now, I’m just using a MutationObserver to check for a textarea and replace that, but as you can see in the attached gif, the textarea shows up briefly (although gif compression exaggerates the amount of time the textarea shows).
wysiwym
Welcome. I don’t think that there is currently another option than a MutationObserver. Could possibly avoid the brief show-up with some css.
Thanks, for the CSS idea, it’s still a bit awkward that the content disappears for a bit but better than the text area showing up :smiley:
wysiwym
