Right now, I want to review all my inputs and, if any of them have the word “governance” I want to convert it in a #hashtag. Are there any tool or procedure, insight of Logseq. I have the markdown 0.10.13 version.
“Logseq Find and Replace Plugin”. Find and Replace across your entire database
If there’s not too many, simply create the page link [[governance]]
look in the unlinked references section. If there is not to many, you can simply add the hashtags there
If there is a lot, I prefer to do this outside of logseq, with a text editor. Many of the more power text editors have a Multi-File search and replace feature.
My current favorite is BBEdit
I do this very frequently to “archive” and “unarchive” tags and project pages
Thank you so much for your idea! Were you reading my mind? I was approaching the problem the way you suggest right now… I think the @Aryan plugin is great (thank you @Harlock for the tip), but it changes the words or phrases in all entries; of the 21 entries I have, there are 2 or 3 that I don’t want to change.
It could work too
thanks
