Hi, I can’t seem to find this already discussed in the forums. But I might just be using the wrong words for it. I am using multiple links in quite a few blocks. Like [[Cookies]] [treats]] [[Baking]] [[Smiles] sugar cookie recipe from grandma…
Is there a feature, or a plug-in, I would allow me to auto add all the links after cookies once I have the link for [[cookies]]?
Often my links are hierarchical, but sometimes just associations.
All comments welcome. If you think I’m doing it all wrong and you know a better way. I’m happy to hear about it.
Welcome. I’m not sure that I understand your requirement.
- If you want to:
- organize your links (these are called references) in a hierarchy, consider using namespaces
- In your example, that would be like
[[Smiles/Baking/treats/Cookies]] - This has some misery potential.
- add predefined text in a quick way, should define and use a macro
- In your example:
- if the definition was like:
:cookies "[[Cookies]] [treats]] [[Baking]] [[Smiles]" - the usage would be:
{{cookies}}
- This would require a separate macro for each predefined text.
- This doesn’t scale.
- Though some parameterization is possible.
- In your example:
- The ideal would be to adopt some workflow that doesn’t require to repeat the same things every time.
- In your example, mentioning
[[cookies]]should be enough.
Not exactly what you’re asking for but text expansion software is useful for this and many other things.
