Be able to adjust the width of content area
Reason:
  1. when my content line in my code block is a little long, it will need to scroll to the right.
  2. when i write a markdown format table, if the content line is a little long, it will cause a forced line break, as shown in the following(my screen size is 13.3 inches):
Came here for this :+1:. Would be nice.
Agreed - after a search I stumbled here - I’d like to use more of the available space for tables. Also - the markdown justification capabilities :—: and :— and —: do not work.
If you go to Settings > Edit custom.css and then paste this snippet, the tables are better:
.table-wrapper {
  width: 100% !important;
  max-width: 100% !important;
table td {
  min-width:100px;
  word-wrap:break-word;
I fixed it with this:
th {
  word-break: keep-all;
You can try using if you do not use wide mode with shortcut keys t w
:root {
  --ls-main-content-max-width: 80%;
I tried this, and tables do look better - columns are now not being squeezed to fit a small width… but I can’t seem to use the tables horizontal scroll bar - when I try to click on the scrollbar, logseq takes the editor into block edit mode :frowning:
