a) im looking for a really good youtube / video showing how to use this, and explains it clearly
ggg
b) also looking for specific uses cases like what you use it for specifically
for example todos is a specific use case but many of us know trello is king in that
example: Trello
so looking for all the other things that logseq would be good for specifically
c) few qeustions
there was i believe a tutorial that showed after install
i created a new note, and now tutorial is gone
how to find it again?
i checked the user interface and cant find it anywhere
i found this thing i forgot how - https://logseq.github.io/#/page/getting%20started
the way this describe things makes it very confusing since itâs using the word âblockâ for no good reason and most ppl do not know what this means, and why would it explain things in a way that the vast majority would not understand?
its better to just say âjust start typingâ
âpress shift enter to continue typingâ
simple plain language
we can see what it does (which is a lot easier and better in seeing what sometihng does), but using strange words like this link makes this pretty useless
itâs also not useful because i cant open each link into a new tab like we can with every other site out there. this makes this site really hard to use since you are limited and constrained into one tab
i think that this link was made for just for techies, or just for the devs that made this app â and was not made for most ppl
as an example, i tested âupnoteâ - it seems to be a good app that replaces evernote
and it has an immpeccable info sheet / tutroial page that just lists all the features very clearly and concisely. w/e team is making âupnoteâ is doing an incredibly but im not sure what use case it would fit yet
i have no idea about logseq either
d) what is or are the main ways or organizing in this?
for example
- it looks like you click the âcontentâ section to edit
- you click the title to âfocus/showâ only that note (looks like you cant edit/change the title which is weird)
but how to create a new note?
i think notes are called âgraphâ in this, but that word is too confusing to me
i clicked on top right > âadd new graphâ > but then it does not open a new note
it says " Open a local directory"
it says a directory is a âfolderâ
but i dont want a folder, i want a new note
how are we suppose to take notes without being able to create new ones?
are we suppose to type in the current âsheetâ or something?
it doesnt explain anywhere why we would want another âfolderâ?
arent we able to hvae more notes within the current âfolderâ?
on top right, âall pagesâ seems to be showing all the notes, this doesnt seem useful since itâs likely youâll have lots of notes
âall filesâ seems to be showing a similar thing
anyway what is or are the main ways or organizing in this?
and i need a really really good youtube that explains everything fully and clearly
any good start guide would tell us this from the beginning
if we wanted to know what were the common ways of organizing, all any of us would do is to look at the common popular apps the world has made. something like this w/e this is is ofc not that
e) are we suppose to organize things using #tags like in evernote?
if so thats ok that means that every new note i have to #tag it with a #title
that works
only if we are able to show all the #tags so that we know what are all the tags
it has to show only the #tags and nothing else since anytihng else would make it hard to find the #tags and thus making it useless
on link above, i clicked the link under âgetting startedâ where it has the #dummy tag
after clicking on the link, this page/link isnt showing the entire note
how do we use #tags to show the entire note?
f) are there font colors in this, i dont see any?
g) it says on the web that this would suggest things after thereâs more notes?
- but i dont know how itâd show it - how would it show it?
- and i dont know itâs going to show - what is ti going to show?
- because thereâs no good video
any really really good youtube / video showing how to use this, and explains these few things and anything else clearly? like in a few of the good apps out there
seeing what specific uses this could be used for, and what gaps in the tools this may be filling
h) copying into almost every other app keeps almost all formmating, copying into logseq does not do thatâŚ
looks like you can copy out though
that means that the use case of copying notes into loqseq is out since itâs not keeping all formmating
