Better visual signposting of collapsed blocks
I often fail to spot collapsed blocks because the visual signposting of collapsed blocks is rather subtle. You have a slight halo around the bullet point, as below.
Is there way to make these more salient? I am thinking of two possibilities, firstly to make the halo brighter / a different colour, and secondly, to add some bread crumbs (preferably brightly coloured) at the end of the collapsed block.
Could this be done by CSS? I can’t seem to find any themes which provide better signposting for collapsed blocks, so I suspect not.
Either:
  • set css var --ls-block-bullet-border-color
  • customize css rule .bullet-container:not(.typed-list).bullet-closed
    • e.g. background-color
Thanks. Sorry, I am not a CSS expert, and I am finding it hard to follow this. So far, I have
--ls-block-bullet-border-color:#f5b505
  .bullet-container:not(.typed-list).bullet-closed { background-colour: #f5b505 }
This is in my custom.css file. It does not do anything.
I do not understand the dot notation, e.g. before “bullet-container”, as this does not seem to be part of standard .css.
Accepted solution:
    background-color: #f5b505
Don’t use both at the same time. Remove the variable (i.e. the first line) and change background-colour to background-color
Oh superb! Thanks very much - works a treat!
