Block calendar not showing
hi,
i don’t know whether here is a right place not ask help on plugins…
i installed plugins “banner + block calendar”, they work fine till today, the calendar doesn’t show up, so far i tried re-install block calendar, and re-set both plugins, but not working.
any hints? thank you
  • Check if other plugins work on not.
  • Try on a new empty graph.
  • Check the console for any clues (Ctrl + Shift + i).
  • If you suspect that it is an issue with the plugin itself, try asking on the specific plugin’s page.
    • Include a description of your efforts up to this point.
hi mentaloid,
happy holiday, thank you for your suggestions, all other plugins working fine, tried on new empty graph, not working as well.
as for console, everything is fine.
i will ask it in the plugin page.
thank you very much
Just provided PR that fixes it. Waiting plugin’s author to approve.
If you want to fix it right now:
1)
2)
3)
Save it & restart Logseq
thank you, let’s see
@baiwj just updated prev post
@stdword indeed, the calendar comes back, thank you very much !
wonderful fixing
PR has been merged, Please update. Thanks @stdword
