If i attempt to add properties to a block using #+property: values i get a very confusing error. If i manually enter:
:PROPERTIES:
:property: values
: END:
It works fine, #+ works perfectly fine for page properties so it’s perplexing.
:PROPERTIES:
:property: values
: END:
This error is displayed when a line inside a block starts with - char.
This char is reserved in logseq to indicate the start of a new block.
Can you share the raw text?
#+tags: #long-term-projects
* Bookshelf Plant Lighting
** Ceiling Lighting
*** TODO affix leds to the aluminum
**** #+task.types: small, physical, task
*** TODO power the light fixtures
@Bader was that what you meant?
I have a similar problem with the properties. Is there a solution?
i changed my formatting for the properties to be like this:
:PROPERTIES:
:task.type: small, physical
: END:
which wasn’t in the docs iirc
