Whenever I link to a block reference in Logseq the link disappears after leaving the block. So if I link to a block in my page on “Yellow Apples” ie [Delicious](block reference) the reference disappears after leaving the block. On Logseq version 0.10.9(83).
Hi.
Do you mean erased or just not displayed?
They’re erased. I’ve tested across platforms and apps with the same result. If I enter the same data structure in Obsidian on the same file the note remains.
Welcome back @logWriter!
How do you reference a block exactly? Do you search by writing (())
, do you click-and-drag, do you click a block and copy its reference, or…? If you could record your screen, that would make it quite a bit easier to help.
Also, what does re-indexing do? Does it properly show the block reference after re-indexing?
Thanks for the reply @Ramses. Sorry for the late reply; I couldn’t reproduce this after re-indexing and restarting machine to take the video. That’s why I waited to reply. Appreciate your willingness to help!
Re-indexing does wonders When a reference isn’t showing up, the best step to take is to re-index as is often fixes the issue.
