Hello everybody,
I have a specific question regarding queries.
I have a template for my meetingnotes that i use every day in my journal.
This template looks like this
- ## Meeting <% today %> <% time %>
template:: Meetingminutes
template-including-parent:: true
category:: meetingnotes
- ## Project/Topic
- ## Attendees
- ## Discussion
- ## Todos
I write a tag for every project in the project session, to link the meeting notes to the specific project.
My question would be, how has the query to be made if I want to query all TODOs inside those meetingnotes with the specific tag for a project?
Thanks in advance
Welcome. Could you provide one or more examples of meeting notes (i.e. a template filled with tags and TODOs)?
For sure
- ## Meeting 2024-06-20 10:00
- ## Project/Topic
- #ProjectA
- ## Attendees
- John Doe
- Dasseh Tugaax
- ## Discussion
- something we discussed
- ## Todos
- TODO Create a pitchdeck
- TODO Do research about XYZ for preparation
- TODO schedule a meeting with Jane Smith
Hope this helps
Can the Project/Topic section contain more than one tags?
- If yes, wouldn’t that mix the tasks from different projects?
- If no, have you considered moving the project tag to either:
- a property, i.e. under
to put project:: #ProjectA
- the Todos section, i.e.
## Todos for #ProjectA
No, I have only one tag per project.
I considered those things, but as I have a mix between internal meetings with no project and project specific notes I wanted to have the template as general as possible. This is the reason why the heading is labeled Project/Topic. When I have an internal meeting/discussion about a topic with no connection to a project I generally write the topic of the meeting.
Here is one way:
{:query [:find (pull ?todos [*])
:in $ ?current-name
[?current :block/name ?current-name]
[?project :block/refs ?current]
[?project :block/parent ?topic]
[?topic :block/parent ?minutes]
[?minutes :block/properties ?props]
[(get ?props :category) ?category]
[(= ?category "meetingnotes")]
[?topic :block/content ?topic-content]
[(= ?topic-content "## Project/Topic")]
[?todos :block/parent ?minutes]
[?todos :block/content ?todos-content]
[(= ?todos-content "## Todos")]
:inputs [:current-page]
Hi there.
Unfortunately this does not give me any result.
Just to make it a bit clearer.
I want this query to be executed on the page for the project, but it should query all the meetingnote blocks in my journal.
I tested it on the example that you provided above, which I pasted in a journal page, and it returns the todos normally. The query itself should be inside page ProjectA
. Try doing the same, or provide more examples.
okay. My mistake.
I changed Project/Topic to Project/ProjectA, because I have also i hirarchy structure of my projects. Works well now thanks so much
