Blocks of specific property, grouped by tag
I have started labeling my blocks (e.g. meeting notes) and TODO items according to related projects and added a duration property to them like so:
I would now like to query for all blocks, which have the duration property and group them by their label to obtain a table or bullet-listing similar to this:
block label duration
One todo item #project_1 1.6
Another todo item #project_2 0.6
(Note: A link/reference to the corresponding block in the first column, would be sufficient as well.)
Is this possible and how?
As a bonus, it would be awesome to be able to sum over all duration values of the same label (i.e. duration of all blocks labelled with #project_1 in the screenshot above). But I would already be very happy to have a grouped list-view.
  • Is there a marker (TODO etc.) used in the TODO items?
    • It is not visible in the screenshot.
  • Where is the duration located?
    • same block
      • This is the typical place.
    • child-block
      • This is how it looks like in your screenshot.
  • Consider providing actual markdown instead of screenshots.
  • The duration-sum-per-label could be a separate query.
Thanks for replying.
Here is is a more complete Markdown example:
- ToDos
	- TODO One todo item #project_1
		- duration:: 1.6
	- ONGOING One todo item #project_1
		- duration:: 0.7
	- DONE Another todo item #project_2
		- duration:: 0.6
- Notes
	- Meeting minutes #project_3
		- duration:: 0.5
		- This is a note from the meeting.
		- This is another note from the meeting
And to answer your questions:
  • Some blocks have TODO marker (or DONE / ONGOING), but not all. As you can see in the example above I also put duration property on Meetings to track how long they took.
    But querying just the TODO/DONE/ONGOING items, would already be very good start.
  • The duration property is always a child-block of the block that I want to query for.
  • Let’s ignore the duration-sum-per-label for the moment, if it can be handled in a separate query (I can do the sum by hand, when I have the correct query).
  • Ensure that all your #project_n pages have a property type:: project
    • This criterion can be customized, but there has to be a way to say which tags are considered projects.
  • Then use the respective query for:
    • sorting:
       :query [:find ?name ?duration (pull ?b [*])
         :keys project duration b
           [?d :block/properties ?d-props]
           [(get ?d-props :duration) ?duration]
           [?d :block/parent ?b]
           [?b :block/refs ?p]
           [?p :block/properties ?p-props]
           [(get ?p-props :type) ?type]
           [(= ?type "project")]
           [?p :block/original-name ?name]
         (map (fn [r]
           (update (:b r) :block/properties (fn [p]
             (assoc p "project" (:project r) "duration" (:duration r) )
         ) (sort-by :project result))
       :table-view? true
    • grouping:
       :query [:find ?p (pull ?b [*])
         :keys id b
           [(get ?d-props :duration)]
           [?b :block/refs ?p]
           (map (fn [r] (:b
               (assoc-in r [:b :block/page] {:db/id (:id r) :block/name ""})
           )) result))
       :breadcrumb-show? false
       :group-by-page? true
    • summing:
       :query [:find ?name (sum ?n-duration)
         :with ?b
           [(* 1 ?duration) ?n-duration]
           [?b :block/refs ?p]
       :result-transform (fn [result] (sort-by :project result) )
       :view (fn [result] [:div
           (for [r result] [:div (str (:project r) ": " (:duration r))] )
