Blocks with only 1 tag
hi,
so far, i tried this, but no work …
{:title "Blocks with Only One Tag"
         [?b :block/tags ?tag]
         [(count ?tag) 1]]}
after some search, i didn’t find any solution
thank you for any hints
  • This should work for pages:
    {:title "Pages with Only One Tag"
     :query [:find (pull ?p [*])
             [?p :block/tags ?tag1]
             (not
                 [?p :block/tags ?tag2]
                 [(not= ?tag1 ?tag2)]
  • This should work for all blocks:
             [?b :block/properties ?props]
             [(get ?props :tags) ?tags]
             [(count ?tags) ?count]
             [(= ?count 1)]
hi,
thank you very much.
regarding the code for blocks, the code is looking for properties ?
sorry, i mean query in journals, where the blocks with only one tage
thank you again
  • Tags are special built-in properties.
    • Therefore, to look for the number of tags, we have to look in the properties.
  • To limit the blocks to those in journals, add these lines:
             [?b :block/page ?p]
             [?p :block/journal-day]
