Somebody is using Logseq and Hugo for website+bloging?
I see there is a plugin logseq-schrodinger by @Aryan (If I’m not mistaken) but has not updates in more than a year, and would like to know if still working for somebody before to start diving into it.
I started using it, realized it was more work to keep it in sync with my blog dev workflow and shifted to now writing my posts in Logseq and manually copying and pasting into my blog workspace. I’d love to see others’ successful workflows for this.
Then exactly how it’s your workflow? I understand you write your post on a page for example, but then, you create a new post in in Hugo directly, and then just export your page as MD without dashes and paste into the created post file? Links and so on keep working?
Regards.
Apologies if my reply was unclear. I’m not using the schrodinger plugin anymore, so at this point, my “workflow” is to do my primary writing as I normally do in Logseq and simply copy and paste that in my hugo blog and remove any formatting related issues, and publish.
So it’s not really a workflow per se, and that’s why I’m interested in knowing how people are generally using Logseq + Hugo.
